bohmwu Posted October 19, 2012 Share Posted October 19, 2012 Just purchased the N40L from buy, received well, first tried win7, nice and decent, however, I need many php and java service, therefore the best way is using linux, or in other words, ubuntu, which is my best choice, I am not expert, and very lack of knowledge. ubuntu was successfully installed on the 250GB hard drive, i had 4 x 2tb, and I set them up as RAID0. in the win7, it worked as it should be, and i used GPT for them. but in the ubuntu, it was been told there is a Raid, and need be activated, i chose yes, and it shows only 1.4tb (with something mapped-h.....), which should be 8tb or at lease 7.2tb in windows. when the installation was done, I couldn't find the location for the series of raid. or because my little knowledge for linux? /dev/sde or else isn't available tried fdisk to check.. like below root@ubuntu:~# fdisk -l Disk /dev/sda: 2000.4 GB, 2000398934016 bytes 256 heads, 63 sectors/track, 242251 cylinders, total 3907029168 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk identifier: 0xa6ee4e1b Device Boot Start End Blocks Id System /dev/sda1 1 4294967295 2147483647+ ee GPT Partition 1 does not start on physical sector boundary. WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted. Disk /dev/sdb: 2000.4 GB, 2000398934016 bytes 256 heads, 63 sectors/track, 242251 cylinders, total 3907029168 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000 Device Boot Start End Blocks Id System /dev/sdb1 1 4294967295 2147483647+ ee GPT Disk /dev/sdc: 2000.4 GB, 2000398934016 bytes 255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk identifier: 0xd41fd41f Device Boot Start End Blocks Id System /dev/sdc1 * 2048 3907026943 1953512448 7 HPFS/NTFS/exFAT Disk /dev/sdd: 2000.4 GB, 2000398934016 bytes 255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x02ed02ed Device Boot Start End Blocks Id System /dev/sdd1 2048 3907026943 1953512448 7 HPFS/NTFS/exFAT Disk /dev/mapper/pdc_hibjbebde: 1404.3 GB, 1404257435648 bytes 256 heads, 63 sectors/track, 170057 cylinders, total 2742690304 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 65536 bytes / 262144 bytes Disk identifier: 0xa6ee4e1b Device Boot Start End Blocks Id System /dev/mapper/pdc_hibjbebde1 1 4294967295 2147483647+ ee GPT Partition 1 does not start on physical sector boundary. Disk /dev/sde: 250.1 GB, 250059350016 bytes 255 heads, 63 sectors/track, 30401 cylinders, total 488397168 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00011008 Device Boot Start End Blocks Id System /dev/sde1 * 2048 499711 248832 83 Linux /dev/sde2 501758 488396799 243947521 5 Extended /dev/sde5 501760 488396799 243947520 8e Linux LVM Disk /dev/mapper/ubuntu-root: 243.5 GB, 243500318720 bytes 255 heads, 63 sectors/track, 29603 cylinders, total 475586560 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000 Disk /dev/mapper/ubuntu-root doesn't contain a valid partition table Disk /dev/mapper/ubuntu-swap_1: 6295 MB, 6295650304 bytes 255 heads, 63 sectors/track, 765 cylinders, total 12296192 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000 Disk /dev/mapper/ubuntu-swap_1 doesn't contain a valid partition table then I installed gparted anyway, My target is (very simple): 1. keep ubuntu (version at least 9) 2. use hardware raid0 for 4 hard drive ------------------------ SINCERELY THANKS INDEED!!!! Link to comment Share on other sites More sharing options...
a15457 Posted November 21, 2012 Share Posted November 21, 2012 Not knowing anything about ubuntu what I'd try is re-installing win7, delete the RAID 0 partion (7.2TBish), blow away Win7, re-install Ubuntu and see if it picks up the 4x2TB disks properly. If you already worked this one out I'd love to know how you did it. Link to comment Share on other sites More sharing options...
