ImTheTypeOfGuy Posted August 25, 2012 Share Posted August 25, 2012 I have a s2008r2 with a raid 5 array that I want to share on my network. I can't get the xbox to access the drive. I had this problem in the past and had to add a user to the security settings but I don't recall what the user was. Anyone know what I have to do? And before you ask, yes, I did go in and share the drive but I may not have done everything required. This is my first time trying to share a drive with s2008r2. Link to comment Share on other sites More sharing options...
jmwills Posted August 25, 2012 Share Posted August 25, 2012 I believe the key was to enable the Guest account and give it permissions. That just seems to stick in my mind for some reason. Link to comment Share on other sites More sharing options...
ImTheTypeOfGuy Posted August 26, 2012 Author Share Posted August 26, 2012 That is on whs, right? This is s2008r2. Link to comment Share on other sites More sharing options...
ikon Posted August 26, 2012 Share Posted August 26, 2012 I would imagine it would be the same thing on both. The issue likely is that the Xbox doesn't have an account that the server recognizes. I don't have an Xbox (haven't even ever played one) but I suppose it's not possible to have logins on it like you would on a Windows PC. If so, I don't know how the Xbox could get authenticated by the server, except or course if the Guest account is enabled. Link to comment Share on other sites More sharing options...
jmwills Posted August 26, 2012 Share Posted August 26, 2012 Not only would you have to enable that built-in account, you would need to create a share that "Guest" has full access to. Link to comment Share on other sites More sharing options...
