bannockburn1314 0 Posted August 17, 2012 Share Posted August 17, 2012 Hi all , greetings fae Scotland.1st off great site huge resource of information. Now for the some backstory , in these times of austerity i'm looking to cut back on outgoing finances and i can no longer justify the cost of sky. So i'm looking to build my own alternative and go down the xmbc route in the hope that the htpc will soon pay for itself. As i mentioned previously great site with loadsa cool builds and googles provides tons of information on htpc builds but unfortunatly alot of that info is over my head which leads me to you guys.I'm not only new to the htpc scene but until 4 years ago i had never owned a pc , however i'm proud to say the 1st pc i owned was built by my own hands.So i have moderate experience in this department.I know from when i built the pc that the 1st big hurdle is compatibility and i can use your help here but before i even get to choosing hardware i 1st have to work out what i need.Hope you guys can help me here.So with all that waffle out of the way here's my situation. WHAT I HAVE - a 15 year old gigantic tv which is on the blink and will soon be replaced with a 40 inch lcd with built in freeview - also have a uk sky hd box that will be given to my sister leaving me with a sat dish and twin cable coming into my house can i use this? WHAT I WANT - a htpc running xmbc that will allow me to watch one channel while recording another - low energy consumption - SSD for main OS to make things snappy and avoid lag in menus etc I've done lodsa googling , reading , window shopping and tons of youtube vids and was all set to start the ball rolling and buy a 2tb wd green for storage but then i read an few forum posts where guys were saying that there were issues with HD video capture and green drives , is this true?. So this is why im here so i dont make any noob mistakes. Basically i don't know what i need yes a case , mobo , cpu etc but when it comes to the recording etc i'm clueless. Budget wise like everyone i'm looking to spend as little as possible , from what i've read this probably means going with amd rather than intel.I wont be gaming just doing everything a sky box would do and i'll probably sell my laptop and use htpc for emails and browsing. Thanks to all that have taken time out to read this and contribute with there suggestions and expertise. Look forward to reading your replies Link to post Share on other sites
ikon 439 Posted August 17, 2012 Share Posted August 17, 2012 First, welcome to the forums. Second, sorry to hear about your financial woes. Third, I would get WD Red drivess instead of Greens. Just slightly more cost, but they're built for 24x7 use. Your only issue will getting hold of them as they're in short supply. Fourth, you haven't really said what your entertainment source is to be. Are you looking to still use Sky TV, but without their box? If not, where will your TV programming come from? I think you need to describe how the HTPC is to be used rather than what hardware to buy at this point. Link to post Share on other sites
bannockburn1314 0 Posted August 17, 2012 Author Share Posted August 17, 2012 woo hoo my 1st reply and from a legend no less. Thanks for the quick response ikon and the warm welcome , apologies for not being clear in my 1st post. OK my sky box will be given to my sister which will leave me with a sky dish and the twin tuner cable , i was wondering if these could be utilised with a htpc to allow me to watch one channel while recording another? i will of course cancel my sky subscription so only the free to air programs will be available. Ok still not being clear i will use my htpc running xbmc what i would like to do is be able to watch something on 1 channel while recording another.I plan to use plugins like icefilm etc can i record these? also want if possible the ability to pause and rewind live tv. Hope that helps im away to check out those WD red drives. Link to post Share on other sites
jmwills 284 Posted August 17, 2012 Share Posted August 17, 2012 I'm not sure if XBMC has the ability to record and watch separate shows. What type of tuner is being used? Link to post Share on other sites
bannockburn1314 0 Posted August 17, 2012 Author Share Posted August 17, 2012 I'm not sure if XBMC has the ability to record and watch separate shows. What type of tuner is being used? Thanks for replying jmwills , the questions you put forward are the questions i need answered as i dont have the knowledge to answer them yet. Link to post Share on other sites
bannockburn1314 0 Posted August 17, 2012 Author Share Posted August 17, 2012 I would get WD Red drivess instead of Greens. Just slightly more cost, but they're built for 24x7 use. Your only issue will getting hold of them as they're in short supply. I was aware of the WD green/blue/blacks but had never come across the reds before so thanks for the heads up ikon.I've managed to source a 2tb for a £99 gbp and i reckon this could be my storage sorted. Is it true that the wd greens should be avoided in terms of hd video capture? and is anyone aware of issues with the wd reds in a htpc? Link to post Share on other sites
ikon 439 Posted August 17, 2012 Share Posted August 17, 2012 Some people in the forums like the Greens, but I, and some others, have found them to be less reliable than other WD drives. I've stopped buying them altogether. Glad to hear you were able to source some. The Reds are brand new, so that may be why you haven't heard of them. They are designed for NAS and other continuous duty applications, so they should be great for an HTPC. As far as your tuning is concerned, I'm not sure how you could use the dish. I suspect you will need a regular UHF antenna, plus a tuner of some kind (either an internal card or external box). This could add several hundred pounds to your total. Link to post Share on other sites
bannockburn1314 0 Posted August 17, 2012 Author Share Posted August 17, 2012 Ok further to jmwills post i'll repost my wishes and hope that you can advise me how to go about this if it's possible. NEEDS - an htpc that has low energy consumption - quiet system - the ability to watch , pause , rewind and record live tv - hopefully the ability to watch 1 channel while recording another - is it possible to record something on xbmc such as icefilms etc while viewing another channel? If the above is possible how do i go about ? what hardware do i need? already decided main OS be it win7 or linux will be on a ssd and it's looking like WD red for my storage , i'll figure out the mobo once i know how many pci slots etc i need. Got a feeling this will be a long thread please bare with me and excuse my noobness but don't mistake it for laziness , i have done many many hours , days , weeks of research but it usually throws up more questions than answers for me. Link to post Share on other sites
bannockburn1314 0 Posted August 17, 2012 Author Share Posted August 17, 2012 As far as your tuning is concerned, I'm not sure how you could use the dish. I suspect you will need a regular UHF antenna, plus a tuner of some kind (either an internal card or external box). This could add several hundred pounds to your total. so something like this is no good for me ? http://www.maplin.co.uk/dvb-s-satellite-pci-tv-card-97820?c=6354&u=rtsatonpc_rfmod as suggested here in option 2 http://www.radioandtelly.co.uk/satellitetvonapc.html Link to post Share on other sites
jmwills 284 Posted August 18, 2012 Share Posted August 18, 2012 Core i3 (Ivy Bridge) and yes Intel, ASUS, Gigabyte Mini ITX MOBo......look at my Signature line for the HTPC's - not saying mine are perfect but they certianly suit the purpose. I think I had around $500 in the system total. Link to post Share on other sites
