Small 'programming' challenge
ikon
I'm not familiar with pushd and popd. I'm very familiar with push and pop in assembly language, but not in this context. I will have to look it up.
Microsoft Windows [Version 6.1.7601]
Copyright © 2009 Microsoft Corporation. All rights reserved.
C:\>pushd /?
Stores the current directory for use by the POPD command, then
changes to the specified directory.
PUSHD [path | ..]
path Specifies the directory to make the current directory.
If Command Extensions are enabled the PUSHD command accepts
network paths in addition to the normal drive letter and path.
If a network path is specified, PUSHD will create a temporary
drive letter that points to that specified network resource and
then change the current drive and directory, using the newly
defined drive letter. Temporary drive letters are allocated from
Z: on down, using the first unused drive letter found.
C:\>popd /?
Changes to the directory stored by the PUSHD command.
POPD
If Command Extensions are enabled the POPD command will delete
any temporary drive letter created by PUSHD when you POPD that
drive off the pushed directory stack.
Yep. I found the same info. It's basically, and not surprisingly, given its name, the same concept as the assembly language push & pop. It just does paths instead of current memory locations.
I believe I now have a working script. I've tested it on my system at home and it seems to work fine. Just have to test it on my client's computers.
