HighPoint RocketRAID 2680 SGL Questions
jmhenry5150
Yep - using on-board video...no need for high power there since this guy will just sit in the corner and do my bidding...
Ok cool - *whew* I thought I was screwed on using this card...
Thanks for the quick reply.
  • Replies 55
  • CablDeViL
    5
  • jmwills
    15
    11
  • jmhenry5150
    16
Posted Images
I really wish there was a simple way to incorporate new drivers into a Windows install ISO. There is a way to do it, but it sure as hell ain't simple.
For XP/2003 it's tricky, that's why we created DriverPacks. But for Win7 and up it's dead simple. Just create a folder at the root of your boot .iso named "$WinPEDriver$" (no quotes) and throw all your uncompressed mass storage/RAID drivers in there. The PE setup sorts it all out prior to showing you the list of available drives/volumes to install to. You could also load the drivers to a USB stick and have it plugged in during OS load. Post-install you can use a utility like my SAD2 script to update all the drivers for the OS in one shot.
After looking at the mobo and the card - it seems there is no "perfect" PCI-E slot to put this in.
The only spot it will fit in is the video card slot - is this ok?
The mobo has:
  • PCI Express 2.0 x16 (1)
  • PCI Express x1 (3)
And this card is a PCI-Express x4
Attached is a quick pic of the expansion slots on the mobo:
Ikon is absolutely correct. Use the x16 should not be an issue. That is the one that works best for me. I have had trouble with other slots on some systems but never that top slot.
Thanks very much for the $WinPEDriver$ info.. First time I've ever heard it. So all I will need is an ISO editor. As far as using a USB stick is concerned, that's what I do now, but it's a PITA - you always have to have that USB stick around, which is just plain annoying.
  • 3 years later...
Well I believe my card has gone bad (HighPoint RocketRAID 2680)...
Tons of these errors in the Server 2012 event log:
Event ID 9 - The device, \Device\Scsi\rr26801, did not respond within the timeout period.
Once these start showing up I can't access the RAID drive in any way and I have to restart the server to get it back up...
I have ordered a new card (exact model) just in case and I was wondering how to replace the card without losing my data...
I know you can recover the RAID from a configuration file - but does anyone have any first hand knowledge of how to do this?
Step by step instructions would be great as I am fearful of losing everything  :mellow:
Thanks in advance!
-Mike
