setting up proliant microserver/whs2011 problem
capall
Hi all,
I'm trying to install whs2011 in my hp proliant microserver but when i do, its not recognizing the drives. Any suggestions ?. am I missing the drivers or something?
thanks
This will sound funny because it happened to me on more than one occasion. Did you reattach the SATA cable to the motherboard or did you not add RAM and are going with the stock 2GB? Also, what does your BIOS say for drives? (Advanced>IDE Configuration>Primary) What is the SATA Controller Mode set to and did you flash the bios?
At least go into the Computer Mgt applet and see if the drives are visible there, and if not, go into the BIOS and check for them there.
hi all,
not sure if the drives were initialized, or at least for the stock drive, or at least I dod not intentionally. The seconed 2Tb drives was not for sure.
Bios is stock bios, v41 7/29/2011
In the bios setup and the Advanced tab /IDE configuration/ .. 3 menus..SATA controller set to ACHI, EMBedded SATA Link Rate set to Auto and Drive Write cache set to Disabled.
should they show up in the Advanced tab of the Bios, ?
sorry yes,
per-Installation disc
look like just documentation about setting up automatic installs.
I wonder do I need to install the storage drivers from HP. I noticed that under the Proliant server support page that whs2011 is not as listed OS, but these are
Microsoft Windows Server 2008 Foundation Edition Microsoft Windows Server 2008 R2 Microsoft Windows Server 2008 Small Business
Do I choose R2 for whs2011 drivers and support?
WHS 2011 is Server 2008 R2. Just install the OS and then see what drivers are missing. If you have a support disc, the missing should be on there. We all have the same box so we can tell you which one to download to a USB stick and load from there.
Again, go thru the install and then what is missing. I am thinking the NIC driver is probably the only one.
thanks,
when I click on "new installation" the install gets stuck on this error
"the installation cannot proceed because a primary hard drive is not detected. To install the storage drivers for the primary hard drive, click Load Drivers"
When I do, it wants me to navigate to them,
and I do (which I had downloaded them from the AMD website), it still did not load them,
