Is it possible to enable sleep mode?
MarkJohnson
I am trying to get my whs2011 to sleep when not in use. I only need it a few hours a day tops. I found no sleep mode for PC in power config, only monitor sleep.
I goodled and seen that this board doesn't even have s1 or s3 enabled in BIOS, let alone windows server doesn't enable it either. Makes sense I guess as servers usually run 24/7.
anyway, I was wondering if these modified BIOSs out there have this feature enabled, or if it is disabled in hardware? I found so many different ones when getting the one I have now, that I thought maybe one had S1 or S3 enabled.
I see Hibernate is available, but disabled by whs2011 by default. But I don't think it will wake except for keyboard since there is no S-staes available.
I see posts on people trying to get lights-out add-on to do it, but I haveen't found anyone with success yet.
I have an Intel CT gigabit card that usally has a wake on lan feature. But would that alone wake it? or does that work in conjuction with the BIOS S-states?
I think my system uses around 40watts at idle with 4 HDDs and an SSD boot drive.
Hopefully someone can point me to a BIOS file with S-states so I can put this thing to sleep when not in use. or to wake from hibernate other than power button.
-=Mark=-
I can't offer advice on turning it off, but leaving it on 24/7 would cost you around $2.40 a month.
40w x 24h x 365d / 1000 x 8c kwh = $28.03 a year.
I see that my ex487 has the option to turn off the hard drives, that would save some power.
Edited by jeffla
Sooooo, less than the price of 1 Starbucks ;)
yes, but if it only runs 3 hrs a day it will be around $0.30 a month or $3.60 a year!
forgot to add, my system allows the drive to sleep after 30 minutes.
I don't think the MicroServer will go to sleep.
No, powercfg -a reports The system firmware does not support S1, S2, & S3 states.
but it does say hibernate has not been enabled.
I was just hoping a BIOS update could fix the S-states.
Still searching
-=Mark=-
Edited by MarkJohnson
Ah ha, I have slight progress. first, I found Wake on LAN in BIOS. For some reason it was listed uunder the Boot tab.
Next I install Lights-Out trial version and hit Standby Now, but get an error. I then enable hibernate powercfg /h on in elevated command prompt. Lights-Out errors out again. I reboot and try Lights-out again and VOILA! Hibernates just fine. Only wakes from power button.
I go to power setting and there is still no sleep modes for PC timer.
I check NIC adapter and see wake this computer is disabled. I enable it and also wake on magic packet as I remember reading some got wake to work, but with only magic packet enabled. Still no wake up, but I didn't configure magic packet and not sure how. I have looked up articles and each ones seems to conflict with the other.
I also found that hibernate is an s-state. It is S4.
Still searching
-=Mark=-
Sweet, I almost got it working.
Lights out sleeps and wakes. I got the computer to put itself to sleep in the power setting. I set sleep mode to hibernate and time to 30minutes.
I found a WoL executable and it works fine. I just need the mac addrress of pc to wake. I even had regular wake on lan working, but it was waking after a couple of minutes. Lights out reported unknown device wake up.
Now I just need to find a way to get win7 to wake anytime I try to access the server. right now I have to manually run the WoL.exe file everytime I want to access the server.
I also get a C++ runtime error from atibtmon.exe. It appears to be an AMD driver issue of some sort.
It says application has requested the runtime to terminate in an unuaual way.
I just looked and the aribtmon.exe error happens when I select powerplay on battery permance to maximize battery life. If I select maximize performance, no isses. I have a UPS connected to my server.
all I seem to have left is figuring how to auto wake magic packets in windows so I don't have to manually run programs to wake. especially on automated programs or torrents.
Still searching
-=Mark=-
