WHS Console will not launch from RDC or Connector
CablDeViL
  • Replies 33
  • CablDeViL
    15
  • jmwills
    10
    7
  • Technogod
    1
Yea but the console wont start up when I remote into the desktop either. So its not on the client side.
A Similar thread....
http://homeservershow.com/forums/index.php?/topic/2496-nuts-my-console-wont-start-properly/
Looks for errors in the log files, particularly in the HomeServerConsole.log file if the console isn't loading. They are on the server in C:\Documents and Settings\All Users\Application Data\Microsoft\Windows Home Server\logs
30/2012 12:25:56 PM c74] WARNING: Comparing Ip -192.168.1.199- -192.168.1.199-
[5/30/2012 12:25:56 PM c74] WARNING: Mismatch External Port 4125 80
[5/30/2012 12:25:56 PM c74] WARNING: Mismatch External Port 4125 443
[5/30/2012 12:25:56 PM c74] WARNING: Comparing Ip -192.168.1.199- -192.168.1.199-
[5/30/2012 12:25:56 PM c74] WARNING: Mismatch External Port 53865 80
[5/30/2012 12:25:56 PM c74] WARNING: Mismatch External Port 53865 443
[5/30/2012 12:25:56 PM c74] WARNING: Mismatch External Port 53865 4125
[5/30/2012 12:25:56 PM c74] WARNING: Mismatch External Port 0 80
[5/30/2012 12:25:56 PM c74] WARNING: Mismatch External Port 0 443
[5/30/2012 12:25:56 PM c74] WARNING: Mismatch External Port 0 4125
[5/30/2012 12:25:56 PM c74] WARNING: Mismatch External Port 443 80
[5/30/2012 12:26:05 PM c74] WARNING: Comparing Ip -192.168.1.199- -192.168.1.199-
[5/30/2012 12:26:05 PM c74] WARNING: Mismatch External Port 443 80
[5/30/2012 12:26:05 PM c74] WARNING: Mismatch External Port 4125 80
[5/30/2012 12:26:05 PM c74] WARNING: Mismatch External Port 4125 443
Interesting!
Looks like your server lost it's reservation perhaps or at least the one port forwarding is mapped to. I did see one link that mentioned this but did not think it was appropriate to your situation.
If this is the case, set a DHCP reservation for the server and reboot. This should take care of this.
As a troubleshooting measure, you could assign a static IP. This would eliminate any possibility that it's actually a DHCP issue. The one thing that is puzzling is that you can get into the server via RDP. That would indicate that the server is getting an IP. Are you RDPing into the server via IP or by DNS?
yea I took care of that issue. Still no love. And the homeserverconsole.log file has not been updated for a month. I am going to delete it and hope it regenerates.
out of the end of the latest Console log file.
1]120413.002338.5971: BackupConfig: Error: Disconnected Backup Config
[1]120413.002338.6127: BackupConfig: Error: Disconnected Backup Config
[1]120413.002348.6127: BackupConfig: Error: Disconnected Backup Config
[1]120413.002348.6127: Error: Stale transport, The RPC server is unavailable. (Exception from HRESULT: 0x800706BA)
[1]120413.002348.8627: Error: Exception thrown
System.Runtime.InteropServices.COMException (0x8007045B): Retrieving the COM class factory for component with CLSID {3AA6FAC6-558C-4A4A-A60A-AC40B048C393} failed due to the following error: 8007045b.
at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
at System.Windows.Forms.Control.Invoke(Delegate method)
at Microsoft.HomeServer.HomeServerConsoleTab.Health.HomeServerTabExtender.Health_DetailedView.RefreshData()
I changed the ip to static and have full internet access on the server. I will try to RDP with the ip and not the name just to check... Ok IP RDP works fine.. Going to run ckdsk on the c drive now
