Shoop Posted May 2, 2012 Share Posted May 2, 2012 I was wondering if WHS 2011 will take advantage of Intel turbo boost processors. I'm not quite sure what power plans whs uses. I read where server 2008 would not because of the default balance power plan. I would assume that since whs 2011 is based of this platform it has the same power plan. Can anyone confirm whether it will or not? Link to comment Share on other sites More sharing options...
pcdoc Posted May 2, 2012 Share Posted May 2, 2012 I was wondering if WHS 2011 will take advantage of Intel turbo boost processors. I'm not quite sure what power plans whs uses. I read where server 2008 would not because of the default balance power plan. I would assume that since whs 2011 is based of this platform it has the same power plan. Can anyone confirm whether it will or not? Turbo boost is native in the BIOS/Chip and should be supported in WHS 2011 You can use a utility like CPU ID to verify. Link to comment Share on other sites More sharing options...
