Icy Dock MB982SPR-2S and 2 WD Blacks - compatible?
nlitend1
I have a WD3200BJKT drive and am thinking about buying a WD3200BEKT (due to the extreme price of the BJKT model) drive to put them both in a RAID 1 in the well liked ICY DOCK MB982SPR-2S enclosure to run it as the OS drive in my WHS v1.
As far as I know, the only difference is the free fall sensor is present in the BJKT drive.
Will these drives work the same and be very stable/compatible in that enclosure? I'm not sure how much the free fall sensor plays into the drive operation in a non-mobile enviroment, so i figured I'd throw it out there for comments. :) Thanks guys!
Here is some info i found on the drives.
http://www.tomshardw...bekt-wd3200bjkt
I would assume it should not be an issue. The docking station works with almost all standard drives.
