WHS 2011 and EARS Drives - Jumper?
C4Tech
I just purchased couple of WD 2TB drives (WD20EARX).
My question should I install the jumper or not?
Also, when the drive is first seen by WHS, I'm asked if it should be partitioned as MBR or GDP.
Which should I pick?
I'm planning on using the drives in a Raid 1 in a microserver for user backup and shared folders.
....thanks....brian
....thanks....brian
As Ikon says, none required by 2011. You should format as MBR for boot drive.
....thanks....brian
Like Ikon & PC Doc said: For WHS 2011 do NOT jumper the EARX or EARS drives.
You can read up on MBR & GPT at Windows & GPT FAQ
I've been using MBR on anything 2TB or less and GPT on anything greater than 2TB
Edited by Joe_Miner
One last note, GPT on the boot is a bad idea. Your motherboard needs to support it and you need third party solutions to restore a GPT. Internal backup will not work. My suggestion is to stay away from GPT for the boot drive.
good catch; forgot about that caveat.
