Power Requirements of N40L MicroServer
Joe_Miner
The MicroServer Owners Club on the OverClockers Australia Forum member Doodz has a comprehensive write-up on the power useage of the MicroServer.
In my own configuration of the MicroServer with:
  • 8 GB RAM
  • Crucial M4 128GB SSD
  • WD20FAEX 2TB Black Drive
  • WD20EADS 2TB Green Drive
  • WD30EZRX 3TB Green Drive
  • ST3000DM001 Barracuda 3TB Drive
  • Intel EXP19402PTBLK 2-port NIC
I found that the MicroServer had a start-up peak of about 101VA (Volt-Amps) ran idled at about 61VA.
In the above configuration I still had one slot open in my 4-bay for another 3.5” spindle drive so in the interest of science I re-installed the original Seagate 250GB drive:
  • ST325318AS Barracuda 250GB Drive
In this “filled” configuration I found that the MicroServer had a start-up peak of about 111VA and ran idled at about 66VA.
    • oldwhs12
      By oldwhs12
    • AVsonyfan
      By AVsonyfan
      Tips:
    • hhvdwatt
      By hhvdwatt
      Hi I am new to forum.
      I have an HPE 40L Microserver and would like to upgrade the motherboard to something a bit more modern.
      From what is can find on this topic it would appear that the motherboard is mini-ITX like but not exactly. Has anyone ever resolved upgrading this with something new that works or should I just replace the server?
      Thx in advance
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
