Synology DS511+ or QNAP TS-559 Pro II
Luzer
I have a Drobo Pro and I think I'm finally ready for a "upgrade". I'm really happy I got the Drobo Pro but now I need something that has a little more horsepower. I got my Pro right when it came out and had only minor issues, mostly my fault, with it. I know I should of got the Elite but I was, and still is, out of my price range. So here we are in 2012 where iSCSI is the major thing and just about every device supports it and you can upwards of 150Mb/s transfer rate. That means the only feature that differentiate between all of the available products are the add-ons the device or the OS/Apps. Side note: having access to the OS, wow. We are in the future.
The main two uses for the NAS would be for an iSCSI target for my WHS 2011 and a little VMware/Hyper-V testing (more like breaking :)). I like the fact that they are both VMware/Hyepr-V certified and support clustering. I also like how they have apps and mobile phone support. But when it comes down to it I don’t want to replace my WHS since it so integrated with my network. I have a client that has the Synology and it a breeze to set up and actually a lot of fun to use. I feel like the QNAP is akin to that old bank that barely has an online presence one ATM down the street whereas the Synology is like Chase (remote check deposit anyone?). They both work but is more fun to use which means you will actually use it. In the same token you set it up them up once and never touch them again until you upgrade. Hence my dilemma.
I have about 5Tb of data I'll be moving.
My list of difference between the two are below and what I think about them:
DS1511+ [Amazon]: $895
(Hardware)
RAM: 3Gb - Purchased 1Gb
eSATA: Yes* - You can use it to add-on their[DX510] ($492) expansion bay or a eSATA drive. Can’t be used for iSCSI volume or added to a drive pool. Only NFS share.
SATA 6Gb/s: No
Wattage: 68W Load 30 Idle
LCD: No
USB: 4
Apps/OS Features:
Apps: Yes - Dont see any I would use
OS Feature: Same
TS-559 Pro II [Amazon]: $904
(Hardware)
RAM: 3Gb – Purchased 1Gb
SATA 6Gb/s: Yes
eSATA: Yes x2 – You can plug any eSATA drive in and add it to the pool.
Wattage: 44W Load 22 Idle
LCD: Yes – It’s a cool feature but not a deal breaker.
USB: 5 – 2 are USB 3
Apps/OS Features:
Apps: Yes – Only one I would use is Asterisk.
OS Feature: Same
My questions about them:
1. Can you use an external drive connected to the eSATA drive on the TS-599 as an iSCSI target or add it to one of the storage pools? On the Drobo it’s only a NFS share.
2. Is Synology Hybrid RAID better than Qnap Online RAID? SHR seem to be the more expandable.
3. How does Time Machine work between both of them? Can I reserve a quota for the backups?
4. Does any have experiences with both that they can shed some light on why you would choose one or the other?
Thanks for the help.
I've no QNAP experience so can't compare, but as for Synology...
I've had the 1511+ with the 510 expansion bay for about a week now. The bay can be used for iSCSI. I'm using the DSM 4 beta so this may be a reason for the difference (I never used DSM 3.2 which is the version shipped on it). I have a block level single-LUN iSCSI set up on it using all 5 drives in the bay. It's a target for my WHS 2011 (for backups). I was also able to set up both other iSCSI target types on it without a problem but went with Block-level across all drives and have been running that for a few days. I could also configure all 10 drives as one big pool for both iSCSI and a file volume.
I did have problems setting up a working iSCSI target from my Windows 7 desktop to the 1511 (whether or not I used the DX510). I think this is more of a problem with something on my Windows 7 PC. I eventually gave up trying to get it to work since I didn't really want only want iSCSI from WHS.
Quota setup for Time Machine are possible but not for the way I use my Macs and the NAS. You can limit a TM backup size per ID but not per computer. A entire volume is assigned to time machine and only one volume can be assigned to Time Machine so all Macs/IDs share the volume for TM backups. Quotas are ID based. I use the same ID on all the Macs and want one Synology ID per person, not computer, so a quota would be meaningless for me.
I didn't find much performance difference between RAID 5 and SHR but in my configurations SHR would have been doing RAID 5 since all the drives were the same size. Doing a raid rebuild was slow when it ran as a background task but disk performance was comparable to a healthy drive during that time. Still, it was a over day to rebuild the 5 X 2TB RAID 5. I also kept all drives in each disk group of the same type. Don't really have too (per Synology) but it makes me more comfortable and I suspect performance is based on the slowest drive in the group.
For what it's worth, I have the base 1GB of RAM and it's been fine. Usage is typically < 40% of RAM when backing up to the iSCSI target and streaming a couple files or copying files from a couple PCs. I don't run a lot of their apps, and for services just WebDav and Network Backup beyond what's enabled by default.
I'm a fan of the Synology but since I've never used QNAP I'm not saying it's a bad choice. I started with the DS212j and became a fan so went with the DS1511+ w/DX510 when I decided to consolidate space. SATA III would have been nice but I'm reusing existing drives which are SATA II anyway. I wouldn't have any plans to upgrade to SATA III until I needed new drives for other reasons. Plus, the way I'm using it I'm not maxing out SATA II speeds. USB 3 was harder for me to leave out but decided since my only need was "possible" future expansion I'd go without.
Good luck with your choice. I don't think Synology will dissappoint you but hopefully someone has QNAP experience for comparison.
Thanks for the reply.
Can you plug in an eSATA drive (not the DX510 bay) to the DS1511 and copy a file to it? I want to know easy it is to do and if you have to restart it.
The more I think about it I know I wouldn't use USB3 since I don't have any USB3 bays or enclosures.
  • 4 weeks later...
Hi Luzer, I was wondering what you don't like about your Drobo since the Pro was one of the units I was thinking about buying and now you have me wondering if I should get one of the units you mentioned.
Don
    • itGeeks
      By itGeeks
      With the size of hard drives these days are more then a 2-bay NAS really needed? How do you all decide how many drive bays are needed??
      Thanks in advance.
    • Al_Borges
      By Al_Borges
      still trying to get out from under a situation where my QNAP has been borked
      apparently  QNAP NAS'S has been subjected to MALWARE infection
      https://www.qnap.com/en-us/security-advisory/nas-201902-13
      I still have access to my shares but I cant access most of my apps nor update or install anything
      QNAP Tech support responded  and is logged into my machine
      This happened after I went ahead and installed firmware update  a week ago
      don't know if I can recover or if I would even trust this box without a full reinitialize
      fortunately,  I did a full system backup before the firmware upgrade -  so I have that going for me at least
      Something is fishy -  QNAP issued 3 firmware updates during March
      So those running QNAP NAS's   take heed
      and for you Synology users -    smile, but recheck your security processes !!!
    • JROrtiz
      By JROrtiz
    • Dave
      By Dave
      Synology C2 Backup Now Available to US Customers
      This is a data backup service that Synology released to EU customers last year.  I remember trying to get it to install and it wouldn't take my CC# because of location.  Fair enough, will it now and how much will it cost?
      Seriously, how much is it?  Ask Google and on March 25th, 2018 it's $14.12.  That's still not a bad price for 100Gb of backup with versioning. Also not bad to consider this as a secondary cloud backup.  (See below for pricing)
      One thing to keep in mine this is a service that falls under Hyper Backup and not Cloud Sync.  The two are very different.  This will be a true back with versioning and not a simple synchronization of a folder in a cloud service like dropbox.  Many a mistake have been made with sync pairs and cloud services!  That won't happen with backup and versions.
      Enable it and Back Up
      In your Synology DSM go to Hyper Backup. Install if you are not using it.  You would also use this app to backup to USB, Amazon S3, Microsoft Azure, etc.
      Select Synology C2 Cloud Backup.
      That should launch a login portal.  If you have used Synology services before and have a login you can use those credentials or create credentials right here.
      Start your free trial for 30 days but prices are still in POUNDS!  That's a pound symbol right?  If it was released to Europe why isn't it in Euros? I'm so confused.    (it is Euro Dave!  I had a brain fart on the Euro symbol.  See response post below.  Embarrassingly laughing at myself on this!)
      It's here where it wouldn't let me proceed last time I tried due to it being a limited trial to EU customers only.  You have to put your CC# in to get the 30 day free trial.  It says i'm in the Europe Frankfort market but the purchase went through.  So, does this mean if the US sinks into the Ocean and all my data goes with it, my photos will be in Frankfort safe and sound?  Sweet!
      This is the last web screen I see as it has now taken me back to Hyper Backup.
      I'm going to choose a small amount to get started with.
      I'm also going to limit the bandwidth of the backup and set Client Side encryption.  The encryption password box will allow you to use the Admin account password so you don't forget what you put here unless your Admin password is less than 8 characters.
      Once you are finished it will ask you if you want to backup now. I said now just to keep the network clean while I'm working but it will backup tonight.  Look at the screen shot below.  See the little arrow by Synology C2?  That is the link to the web portal.  It would be nice to see Synology integrate this into DSM so there isn't a secondary screen needed.  It would also be nice to have some choice as to where your data is being sent and to be charged a proper amount.  I'm afraid my bank might also charge me a fee for the Pounds to USD conversion.  I'll update the post when I find out.
      Here are the web portal screens below.
      That's it.  It works!
    • Mario P.
      By Mario P.
      I have old WHS v.1 20-bay movie server.
      Few years ago I bought QNAP TS-415+ with 4Tb drives setup in RAID5.
      I really like PLEX on QNAP and started moving/transcoding my movies from WHS to QNAP.
      Well, my 4-bay QNAP is full.
      I need to get a larger one.
      I'm looking at 8-bay ones and just don't think it'll be large enough once I start getting more BD movies, and especially once 4K movies start moving into my home (probably 1-2 years away).
      8-Bay units setup in RAID6 with the largest 12TB drives will be limited to 72TB. I have immediate use for about 30TB -- that's 42% of maximum 8 bay capacity.
      I don't really need much processing power, but am afraid to run out of space again.
      Also, I don't want to get a power hungry monster (like my 20-bay WHS was) because I want to keep running it 24/7 and electricity was in the order of $28-40 per month.
      I like QNAP. I would like to get another one but looking at prices of $3,500-$6,000 for 16-bay unit just seems high -- really high.
      Is QNAP overpriced, or are the components just that good/pricey for what I get.
      Again, I don't need much processing power (no need for VMs, CPU heavy tasks beyond PLEX transcoding), just large space (80+TB).
      What have you or would you do?
      P.S. I would prefer Intel CPU if at all possible.
      TIA,
      Mario
