Sign in to follow this
Server Grunt
Hyper-V vs VMWare - What Virtualization platform for me to use?
Server Grunt
Hi,
Having now decided on my server build and ordered the parts (see my concluding answer at http://homeserversho...ild-re-visited/)
and I am now busy with figuring out the virtualization alternatives.
Being a beginner at virtualization, I have been looking around the net and trying to get the picture on which way is the best to go, but not really coming up with a non-commercial (written by VM or Microsoft affiliates) "comprehendible, match by match and focused on why to use either or system as a start for Virtualization" -analysis on the pros and cons of VMware and Hyper-V.
Original intention to run a one box virtual environment using Server 2008 R2 as host (and it would also manage my home NW environment, group policies etc.).
Guests would include:
  • WHS2011 production server storage/back-up, video streaming
  • 2xW7 Production PC
  • WHS 2011 test server
  • W7 test pc
  • W8 test pc
Usage/tasks:
  • WHS for storage and back up
  • W7 for work
  • W7 and/or WHS for media management (TV- streaming/video & music; encoding, trans coding), photo editing etc
As you see the virtual clients need access to hardware, including PCI and USB for this to work properly
In short - When is either to prefer, why should I choose on or the other for my home virtual box etc and
based on my use case and need to let the clients have access to at least PCI ( I can live without USB back-up), should I go with:
  • Continue with original plan (2008 R2 + Hyper V)?
or
  • Run VMware as host for everything, including Server 2008 R2?
or
  • Use both VMware – as briefly described on tinkertry.com?
And
Why?
Hope that this forum can shed some light
Br,
Grunt
Edited by Server Grunt
jmwills
Do you already have the equipment? VMWare is VERY particular about he hardware requirements.
Guest no-control
In short.
Hyper-v will be the easiest and most compatible with the guest VMs you want to run. depending on how complicated your networking portion is Hyper-V may have a steep learning curve.
VMware (ESXi) is going to be the most flexible with what you can do with it overall. It is very picky about the bare metal hardware it sits on though. I also find its interface rather....lacking. this may be my Microsoft o/s experience/preference showing through.
Using both Hyper-V on top of ESXi is going to be an order of magnitude more difficult to setup and manage. I would not suggest this without having extensive knowledge of BOTH platforms first.
pcdoc
I agree with no-control. I have tried both and can tell you for all the tasks you have listed except for the production W7 will work fine on Hyper-V. The issue with Hyper-V that I have had have been in USB support. ESXi is very flexible and I had not issues with the hardware I used but the learning is much greater. Take a look at the write up I did.
http://thedocsworld.net/esxi-venture-part-1/
jmwills
Both are relatively on the same level now, as Doc said, ESXi does pass thru USB devices whihc will help WHS 2011 in the backup scheme. It mainly depends on what you feel comfortable with. ESXi will give you more available resources for the clients and you can run ESXi from a thumb drive whereas you cannot do Server 2008.
timekills
All windows guest OSs - use HyperV.
I manage adminsitors of ESXi at work for military, including HyperV on ESXi (and do some admin myself when necessary and my managment skills have failed me) but HyperV at home. Why? See sentence 1. NoControl has written some good info on this site, and could certainly have gone into more detail but it is as he says. There are also some posts on using a workstation OS (i.e. Win7) as host and a virtualization platform on top of that. Unless this is a purely test WHS install, you do not want to go that route.
ikon
I thought management skills in the military consisted of, "do it, or else!" :) j/k (I'm ex-military myself so I understand the meaning of leadership.)
jmwills
or as the DI in PI told me. (&*^$%*)*&%@@%*)(*&&^%$^^%%$@!!^( your butt all the way to Hollywood!
Server Grunt
Guys! As always the community spirit here is on an unbelievable high level and your competence and insights are incredible!
Overall: From your answers i gather
If only Microsoft OS in clients go with Microsoft based host, e.g. Hyper-V- but USB bsck-up could be problematic
@jmwillis: Yes, HW ordered and on its way, se my HW list here: http://homeservershow.com/forums/index.php?/topic/3249-crowd-sources-server-build-re-visited/page__p__35797#entry35797
But having looked at tinkertry and on talking to ASRock, the MB, CPU, RAM should work with VMWare - Rocket raid card I am more unsure of.
@No-control: I guessed that running a hypervisor in another hypervisor would be VERY complicted...
@Pcdoc: Thanks, I will look at your recommended link
@ikon: Well, the choice of a hypervisor instead of for example W7-virtualization features, is simpy the more powerful options and flexibility (also a great portion of my "Geek-desire" to learn :-D)
Questions:
  1. With Hyper-V USB back-up could be problematic, but I have read somewhere that RDP could help with USB, or is this wrong?
  2. In general ESXI and Hyper-V, with a few notable exceptions, have similar capabilities and functions - BUT what are these and how do they actually impact?
  3. In what way is the ESXI UI "lacking" compared to Hyper-V?
  4. Then something I am a little puzzled about - can I run ESXI on Server 2008 R2, or must I run it "bare bone"?
/Grunt
jmwills
I just installed my first Rocket Raid card (2720) and I am very pleased. Easy installation, great UI, and FAST!
ESXi is Bare Bones. You install the OS and then download the management piece (VSphere) from the server you just built via its IP Address. The VSphere piece will run from any client on your LAN. The UI for ESXi is very clean and easy to use if you have used VMWare workstation in the past.
Hyper V can also be bare bones but I think I have only heard of one person doing that. ESXi saves resources because of the minimal install; an 8 gig USB stick will do just fine.
    • StevieD
      By StevieD
      Hi all,
      Got myself a Gen8 a while back and starting to set it up now properly. I had one 3TB disk in there to start off with testing the G1610T which was a little slow so I change that out to a Xeon(R) CPU E3-1265L V2 @ 2.50GHz.
      Now I am adding 3 more 3TB disks for a total of 4 and the logical drive now will be a 750GB 2.5" WD laptop drive connected to the ODA port (thanks for the youtube instructions).
      I installed Vmware ESXI 6.5 and it seems the raid controller B120i is not showing up as it should.
      When RAID0 was selected and created in the BIOS this did not reflect on the datastore (which showed only one disk), I understand this means the B120i and I need to obtain a driver (from where?)
      Pictures attached
      Do you recommend RAID0 for esxi I would like the use of all 12TB? This is only for a home server and the important data will be backed up externally and periodically.
      thanks in advance for any help
    • JackoUK
      By JackoUK
      £118 quid for an entry-level  server? Impossible!
      https://www.serversplus.com/servers/tower_servers/hpe_tower_servers/837826-421
    • flammeur
      By flammeur
      Hello folks,
      I have purshace a gen10 and would like to install vmware (any version) on it.
      I tryed to put the custom hp image for vmware on an usb but my ssd or hdd are not detected, so i install the OS on the usb key but vmware still doesn't detect any disk.
      I also installed the boot iso directly on the ssd but it won't boot up on it
      i was checking to create a custom image but i am lost in the settings and didn't find any tutotrial on it
    • Joe_Miner
      By Joe_Miner
      By: JohnStutsman
      Figure 1 – The Calhoun Technologies HP 686745-002 “Refurbished” drive-cage in anti-static package with Dell 15” mini SAS cable resting on top with other drive-cages and HPE ProLiant ML10v2 Server
      A year ago when I was planning my move to Ohio I wanted to move my 5TB drives from my HPE ProLiant ML30 Gen9 to my HPE ProLiant ML10v2 in order to set up a “Mirror” backup of the files on my WHS2011 system using AllWay Sync on my ML10v2. The fastest way to make the move was to unplug the drive-cage in the ML30 Gen9 and plug it into the ML10v2! It fit perfectly and worked flawlessly. It also spoiled me!
      After settling in Ohio, finally, I wanted to return the ML30 Gen9’s drive-cage to its rightful place and I began searching for the best low-cost way to add a drive-cage to my ML10v2 that worked like the one in the ML30 Gen9 instead of the stock ML10v2 drive-cage. There’s a great discussion in the HSS Forums documenting forum members search for a similar drive-cage.
      Figure 2 – Pages 18 & 19 of HPE ProLiant ML30 Gen9 Server “Maintenance and Service Guide”; Part Number: 825545-001; December 2015; Edition 1; shows a spare part number 792351-001 for the Four-bay LFF Hot-plug drive backplane assembly which would include the a) Drive backplane and Drive cage – Part 792351-001 is the part I first looked for and found at Calhoun Technologies.
      After reading some great suggestions in the Forums I stumbled upon the 792351-001 in the parts number of the ML30 Gen9 manual and thought it should fit the bill and found a low-cost option at Calhoun Technologies for a 792351-001 “Refurbished”.
      Figure 3 – ML30Gen9 drive-cage (also 686745-002 footprint) compared to 792351-001 on bottom – the sharpie markings show how much wider the front of the 792351-001 frame is compared to the 686745-002 and why the front cover of the ML10v2 wouldn’t close on the 792351-001.
      The 792351-001 did work in my ML10v2 but I could not close the front cover on the ML10v2, so I kept looking while also trying to modify the 792351 with my Dremel. I could make it fit finally, but only after a lot of Dremel work and the end result didn’t look good.
      Figure 4 – Tag identifying the drive-cage assembly in ML30G9 as: HPE P/N 674790-002 Replace with spare HDD Cage, 4Lff, $u Gen8 Enhanced (686745-002) LITEON (Rev. 15-11-17. The 686745-002 that arrived was identified with a similar tag: HP P/N 674790-002 Replace with spare HDD Cage, 4LFF, 4U Gen8 Enhanced (686745-002) LITEON (Rev.A) 14-03-17.
      On the drive-cage out of the ML30 Gen9 I found the part number 686745-002 which I thought was the part number of the cage alone. (I was wrong about that!) I found it at Calhoun Technologies listed as HP 686745-002 “Refurbished” SPS-HDD cage 4LFF 4U Enhanced. Thinking that it was likely only the drive-cage without a backplane I ordered it since with the 792351-001 I had an extra backplane. I was wrong! The part number referred to the assembly of the drive-cage and backplane.
      As the following pictures will show the 686745-002 arrived with a backplane and it appears to be working flawlessly.
      Figure 5 – Front and Back of Calhoun Technologies HP 686745-002 “Refurbished” SPS-HDD cage 4LFF 4U Enhanced
      Figure 6 – Picture of backplanes L-R: ML30G9 Drive-Cage, 792351-001, and 686745-002
      Video of my installation of the 686745-002.
      Video 1 – Install Drive-Cage in HPE ProLiant ML10v2
      Figure 7 – Calhoun Technologies HP 686745-002 “Refurbished” SPS-HDD cage 4LFF 4U Enhanced installed in HPE ProLiant ML10v2
      Figure 8 – HPE ProLiant ML10v2 powered up and all 3.5” drives functioning in Calhoun Technologies HP 686745-002 “Refurbished” SPS-HDD cage 4LFF 4U Enhanced
      Thanks to the members of HSS Forum Thread: ML10v2 Drive-Cage for their many insights and suggestions and thanks to forum member ToyCeli22 for starting the thread.
      Figure 9 – 686745-002 drive-cage installed in ML10v2 on left and stock 674790-002 drive-cage back in the ML30Gen9 on right
      In the As-Built that follows I list how this ML10v2 is loaded. Be sure to check out more on this at ML10 and ML10v2 Forum and ML10v2 Drive Cage Forum Thread.
      As-Built (I named my Computer: SkyNet)
      HPE ProLiant ML10v2 Server Xeon E3-1220v3 32GB Unbuffered ECC RAM KVR16E11K4/32 OS: Windows 8.1 Pro B120i Logical Drive 01: OS drive – 1 x Corsair Force GT 240GB SSD in RAID0 on HP Dynamic Smart Array B120i RAID Controller – Port 1 (SATA III or 6GB/s) -- Icy Dock ExpressCage MB326SP-B Bay 1 B120i Logical Drive 02: Data drive – 1 x Samsung 256GB 840 Pro SSD in RAID0 on HP Dynamic Smart Array B120i RAID Controller – Port 2 (SATA III or 6GB/s) – Icy Dock ExpressCage MB326SP-B Bay 2 B120i Logical Drive 03: Data drive -- 4 x WD10JUCT 1TB 2.5” HDDs in RAID10 on HP Dynamic Smart Array B120i RAID Controller – Ports 3, 4, 5, & 6 (each SATA II or 3GB/s) – Icy Dock ExpressCage MB326SP-B Bays 3, 4, 5, & 6 P222 Logical Drive 01: Data drive – 4 x WD 5TB SE HDDs (WD5001F9YZ) in RAID5 on HP Dynamic Smart Array P222 RAID Controller Card – Ports 1, 2, 3, & 4 (each SATA III or 6GB/s) – mounted in Bays 1, 2, 3, & 4 of drive-cage 686745-002 “Refurbished” Calhoun Technologies Drive-cage 686745-002 “Refurbished” SPS-HDD cage 4LFF 4U Enhanced; Dell Poweredge T710 PG9KK Mini SAS SFF-8087 cable 15” (38cm) Icy Dock ExpressCage MB326SP-B (I used the existing SATA cable that had gone to the optical drive for bay 5 plus a Blue 18” SATA cable I had in stock from previous projects for Bay 6; StarTech Model SAS8087S450 19” (50cm) Serial Attached SCSI SAS Cable – SFF-8087 to 4x Latching SATA for Bays 1, 2, 3, & 4; I also used a Molex Y to two SATA Power Connectors) 60mm Fan mounted near the bottom front of ML10v2 to increase air flow for the P222 60mm Fan mounted in empty card slot to direct air flow directly on P222 heat sink (plus Molex to Fan splitter and Y Fan to 2 Fan connector cable)
       Please join us in the HSS Forums to discuss this and many other interesting topics.
      References:
      Check HSS Forum Post: http://homeservershow.com/forums/index.php?/topic/10796-ml10v2-drive-cage/
      Scsi4me.com 3.5” Drive Tray Caddy 4 HP ProLiant ML350e ML310e SL250s Gen8 Gen9 G9 651314-001 http://www.ebay.com/itm/231001449171
      Dell Poweredge T710 PG9KK Mini SAS SFF-8087 to SFF-8087 Cable 15” (38cm) https://www.amazon.com/Dell-Poweredge-PG9KK-SFF-8087-Cable/dp/B00NOEY3OS/ref=pd_sim_147_9?_encoding=UTF8&psc=1&refRID=1ZRF07DQQ5V1M36D045C
       HPE ProLiant ML30 Gen9 Server; Maintenance and Service Guide (Item 18 on pages 18-19 lists a Spare part number 792351-001 Four-bay LFF Hot-plug drive backplane assembly – this was where I initially got part number 792351-001 that I ordered from Calhoun Technologies – as stated earlier I found that it did work but I was unable to close the front cover of the ML10v2 or ML30G9 when that part was installed) http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c04905980-1.pdf
      Calhoun Technologies HP 686745-002 Refurbished http://www.calhountech.com/products/hp-686745-002-4-bay-sas-sata-lff-hot-plug-drv-cage.html
      Additional Fans in the HPE ProLiant ML10v2 http://homeservershow.com/additional-fans-in-the-hpe-proliant-ml10v2.html
      Installing Icy Dock 5.25” ExpressCage MB326SP-B http://homeservershow.com/installing-my-icy-dock-5-25-expresscage-mb326sp-b.html
      Other HSS ML10v2 Blog Postings: http://homeservershow.com/tag/ML10v2
      HSS HP ProLiant ML10v2 postings: http://homeservershow.com/forums/index.php?/forum/98-ml10-and-ml10v2/
      Check out my ML10v2 Play List:
      Unboxing Drive Caddies for my ML30 G9
    • Dave
      By Dave
      Panos Panay just wowed the Microsoft crowd with two incredible hardware reveals. The first was the SurfaceBook i7 with a whopping 16 hours of battery life.  The second was Surface Studio. I dare you to call it an "All in One" after today.
      I'll be chatting about all this gear on my new podcast, RESET. Find it here: mccabe.io
      Surface Studio
      The specs of Studio are impressive but visually it is stunning. It has 28" of wow that can be manipulated to however you prefer to create.
      Screen: 28" PixelSense Display
      Resolution: 4500 x 3000 (192 DPI)
      Color settings: Adobe sRGB, DCI-P3 and Vivid Color Profiles, Individually color calibrated
      Touch: 10-point multi-touch
      Aspect Ratio: 3:2
      Surface Pen
      Zero Gravity Hinge
      Quad-core 6th Gen Intel Core i5 or i7
      NVIDIA GeForce GTX 965M 2GB GPU GDDR5 memory or NVIDIA GeForce GTX 980M 4GB GPU GDDR5 memory
      It looks like a creative persons dream machine.  Apple picked a bad week to follow Microsoft when it comes to hardware reveals.  I personally would like to try the Studio and Dial with some video editing software.  I think it will be great for that.
      Look at the Microsoft Store online for more photos.  It really is a nice looking Surface. Link Here.
      Surface Book
      The Surface Book is plain and simple; More.  More graphics and more battery.  It's a little heavier and starts at 3.6 pounds where last year's Surface Book was 3.3 pounds.  Maybe it's the new 6th Gen Intel Core i7 or the i7: NVIDIA GeForce GTX 965M with 2GB of GDDR5 memory.  That's nice but Panos stated they just put in more battery!  It's nice to see that.  Adds a little weight but for those that want the battery life it's a welcome change.
      Surface Dial
      The Dial is impressive.  It's compatible with any Windows 10 enabled PC, laptop, or tablet as long as it has the Anniversary Update.  Don't try this with your Surface Pro but it will stick to the screen of the Surface Studio!  It will have optimized off screen compatibility with Surface Book and SP4.
      It's a jog dial on steroids and Panos and software partners demo'd many uses of it. Color wheel, zoom in, etc.  It's $99 and can be purchased now for delivery on November 10th.
      Thanks for shopping with my links.  Maybe I can get one too!
