Hyper-V vs VMWare - What Virtualization platform for me to use?
Server Grunt
Hi,
Having now decided on my server build and ordered the parts (see my concluding answer at http://homeserversho...ild-re-visited/)
and I am now busy with figuring out the virtualization alternatives.
Being a beginner at virtualization, I have been looking around the net and trying to get the picture on which way is the best to go, but not really coming up with a non-commercial (written by VM or Microsoft affiliates) "comprehendible, match by match and focused on why to use either or system as a start for Virtualization" -analysis on the pros and cons of VMware and Hyper-V.
Original intention to run a one box virtual environment using Server 2008 R2 as host (and it would also manage my home NW environment, group policies etc.).
Guests would include:
  • WHS2011 production server storage/back-up, video streaming
  • 2xW7 Production PC
  • WHS 2011 test server
  • W7 test pc
  • W8 test pc
Usage/tasks:
  • WHS for storage and back up
  • W7 for work
  • W7 and/or WHS for media management (TV- streaming/video & music; encoding, trans coding), photo editing etc
As you see the virtual clients need access to hardware, including PCI and USB for this to work properly
In short - When is either to prefer, why should I choose on or the other for my home virtual box etc and
based on my use case and need to let the clients have access to at least PCI ( I can live without USB back-up), should I go with:
  • Continue with original plan (2008 R2 + Hyper V)?
or
  • Run VMware as host for everything, including Server 2008 R2?
or
  • Use both VMware – as briefly described on tinkertry.com?
And
Why?
Hope that this forum can shed some light
Br,
Grunt
Edited by Server Grunt
  • Replies 67
  • jmwills
    18
    15
  • Server Grunt
    11
Guest no-control
In short.
Hyper-v will be the easiest and most compatible with the guest VMs you want to run. depending on how complicated your networking portion is Hyper-V may have a steep learning curve.
VMware (ESXi) is going to be the most flexible with what you can do with it overall. It is very picky about the bare metal hardware it sits on though. I also find its interface rather....lacking. this may be my Microsoft o/s experience/preference showing through.
Using both Hyper-V on top of ESXi is going to be an order of magnitude more difficult to setup and manage. I would not suggest this without having extensive knowledge of BOTH platforms first.
I agree with no-control. I have tried both and can tell you for all the tasks you have listed except for the production W7 will work fine on Hyper-V. The issue with Hyper-V that I have had have been in USB support. ESXi is very flexible and I had not issues with the hardware I used but the learning is much greater. Take a look at the write up I did.
http://thedocsworld.net/esxi-venture-part-1/
Both are relatively on the same level now, as Doc said, ESXi does pass thru USB devices whihc will help WHS 2011 in the backup scheme. It mainly depends on what you feel comfortable with. ESXi will give you more available resources for the clients and you can run ESXi from a thumb drive whereas you cannot do Server 2008.
All windows guest OSs - use HyperV.
I manage adminsitors of ESXi at work for military, including HyperV on ESXi (and do some admin myself when necessary and my managment skills have failed me) but HyperV at home. Why? See sentence 1. NoControl has written some good info on this site, and could certainly have gone into more detail but it is as he says. There are also some posts on using a workstation OS (i.e. Win7) as host and a virtualization platform on top of that. Unless this is a purely test WHS install, you do not want to go that route.
I thought management skills in the military consisted of, "do it, or else!" :) j/k (I'm ex-military myself so I understand the meaning of leadership.)
Guys! As always the community spirit here is on an unbelievable high level and your competence and insights are incredible!
Overall: From your answers i gather
If only Microsoft OS in clients go with Microsoft based host, e.g. Hyper-V- but USB bsck-up could be problematic
@jmwillis: Yes, HW ordered and on its way, se my HW list here: http://homeservershow.com/forums/index.php?/topic/3249-crowd-sources-server-build-re-visited/page__p__35797#entry35797
But having looked at tinkertry and on talking to ASRock, the MB, CPU, RAM should work with VMWare - Rocket raid card I am more unsure of.
@No-control: I guessed that running a hypervisor in another hypervisor would be VERY complicted...
@Pcdoc: Thanks, I will look at your recommended link
@ikon: Well, the choice of a hypervisor instead of for example W7-virtualization features, is simpy the more powerful options and flexibility (also a great portion of my "Geek-desire" to learn :-D)
Questions:
  1. With Hyper-V USB back-up could be problematic, but I have read somewhere that RDP could help with USB, or is this wrong?
  2. In general ESXI and Hyper-V, with a few notable exceptions, have similar capabilities and functions - BUT what are these and how do they actually impact?
  3. In what way is the ESXI UI "lacking" compared to Hyper-V?
  4. Then something I am a little puzzled about - can I run ESXI on Server 2008 R2, or must I run it "bare bone"?
/Grunt
I just installed my first Rocket Raid card (2720) and I am very pleased. Easy installation, great UI, and FAST!
ESXi is Bare Bones. You install the OS and then download the management piece (VSphere) from the server you just built via its IP Address. The VSphere piece will run from any client on your LAN. The UI for ESXi is very clean and easy to use if you have used VMWare workstation in the past.
Hyper V can also be bare bones but I think I have only heard of one person doing that. ESXi saves resources because of the minimal install; an 8 gig USB stick will do just fine.
    • BacksBen
      By BacksBen
      Hello,
      I am using https://www.digi.com/products/networking/infrastructure-management/console-servers/digi-connect-it-16-48 (Digi Connect IT 16), and connecting by LAN to a Windows PC.
      I need to add 2 connectors. Can I connect a serial device to a serial port in PC and see it as a COM port in the local PC?
      Can Serial to Ethernet (https://www.serial-server.net/serial-device-server/serial-to-ethernet/) do this? How to configure it?
      Thank you,
      Ben.
    • Giuseppolino87
      By Giuseppolino87
      Hi everyone, today I wanted to install esxi 6.7 to try out the various functions, my question is the following, I have a server where I have installed esxi in an SSD and I have two other 4 tb disks so 8 tb total.  I would like to make sure that when I create a virtual machine in this case I will install the various virtual machines in the SSD and use the two disks for data.  So how can I do this?  Thank you very much for those who can help me.
    • E3000
      By E3000
      Hello all,
      A few questions for those who use Type-1 Hypervisors on their Gen8 MicroServers...
      I am looking to try ESXi or ProxMox and have been reading a lot of the threads on here.
      Hopefully you guys can help with some harder to find answers I have been seeking.
      1) Which would be the better way to setup ProxMox:
           a) Hypervisor on Internal MicroSD, VMs installed on SSD in ODD Port, Data on 4x HDDs in bays.
           b) Hypervisor on Internal USB, VMs installed on SSD in ODD Port, Data on 4x HDDs in bays.
           c) Hypervisor and VMs both installed on same SSD (partitioned?) in ODD Port, Data on 4x HDDs in bays.
           d) Hypervisor on SSD using a USB-to-SATA cable on Internal USB, VMs installed on separate SSD in ODD Port, Data on 4x HDDs in bays.
      2) Would a 128GB SSD be a ‘waste‘ for installing a Hypervisor on? How much space is typically needed?
      3) How many VMs have you guys run on a Gen8 comfortably without it being sluggish?
      4) Everyone seems to be going RAID crazy these days. Is there any reason to use it if high-availability is not that necessary and a good backup plan is in place? What is wrong with separate disks (or singular Raid0s)?
      5) Does using Type-1 Hypervisors have any effect on the internal fans speed/noise? Is it possible to have 3-5 VMs running and still have the fan speed @~8% as it was when I was using 2 nested (Type-2) VMs?
      Sorry in advance if some of these questions are silly, common knowledge, or “depends on what you are doing in the VMs!” 😆
      Thanks in advance to all those that help!
    • AllanHP
      By AllanHP
      Hello guys, i have a HP ProLiant ml350p g8 I had installed one gpu card rx580 strix and I had used one gpu frequency  management call asus gpu tweakll, when I change gaming mode to silence mode my computer restart and I saw one red light on the motherboard, I fix the problem I had installed one old version of the asus tweakll, now the computer works well, but the red light still on, I used the software OCCT I checked psu memory gpu voltages run many testes and pass in all tests, I try to find in the manual what this red light is but I can't find, thanks for the help.
    • Tikanderoga
      By Tikanderoga
      Hi all
      Long time lurker.
      I've been running a G7 and now a G10 MS with Esxi 5.5, now 6.7 i think, and I'm getting tired of it. It then is a Server 2012R2, running my files and media content.
      Also in the fray is an LSI 9210 Raid controller. Used to run Raid 5, but the raid kept degrading and I had to run the software to configure from a bare metal installation or rebuild from the menu, meaning the raid was more in rebuild than in actual use.
      I'm thinking about going bare metal,  install Server 2016 and backup the whole stuff regularly to an external NAS, which I've been doing for the past 20 months as it is already with Veeam.
      In case of need for a VM, i've been thinking of firing up HyperV. I know Gen10 doesn't support pass through, so that's one of the main reasons to de-virtualise.
      Also thinking about removing the Raid card in the process, going back to stock gear.
      Thoughts and suggestions?
