Joe_Miner
ESXi 5 on MicroServer?
ikon
Yes, try another stick. I've found the Kingston GT101's to be reliable as boot sticks.
LoneWolf
Interesting question (and I agree on trying another USB stick, the Kingston GT100 works well too, used it to flash the BIOS):
Has anyone found a way to get the HP Remote Access Controller to work with ESXi? I've heard tell it's not compatible, which makes sense; I can't think of a way you could connect to individual VMs through it, which would limit access to a VCenter console.
jmwills
If you have vCenter....why do you need anything else?
CablDeViL
I will have to purchase them TY! I just burned it and booted from my USB DVD Drive. She is loaded and ready to install VMs.
a15457
Ikon, just had a quick look at that review ... awesome work ... nice little device ... aaaaaaand available in Aus! Yaaaaaay! When I have money for toys again next year Ima gon git me one! :D
CablDeViL
OK how many VMs are you running on your N40L? My second one is now installed. It's not the memory I am worried about but the CPU.
jmwills
CPU is fine.....it's the memory as long as you don't fire them up all at once.
ikon
Thanks. I keep mine handy, often taking it with me, since it's so small and easy to transport.
CablDeViL
Another option you could consider is the Zalman VE200. I use mine all the time. I reviewed it here: http://homeservershow.com/review-zalman-ve200-external-hard-drivevirtual-drive-enclosure.html
Typical me not to stay with the forums. But thanks ikon that is some sharp hardware. And I need that to add to my hardware list!
Shoot out of stock.  You snooze you loose
    • Mark Belanger
      By Mark Belanger
      Greetings,
      I'm new to the HPMSG8 world and so far I'm loving it. I have a stock Xeon with 16G of aftermarket memory with iLO patched to 2.70. Next up is adding a RAID card, so I can put my boot SSD on the onboard RAID. I picked up a LSI SAS9211-8i on Amazon, but am struggling to flash it to IT mode on the MicroServer. Is this even possible? Unfortunately, the only other system I have with PCI slots is 32-bit.
      Any pointers would be greatly appreciated.
      -MB
    • npapanik
      By npapanik
      FYI, I have just installed Windows Server 2019 Standard (Desktop Experience) using the latest (WS2016) HP AMD chipset & VGA driver. Everything is recognised in Device Manager and stable.
    • TonyTheTechie
      By TonyTheTechie
      I need to update the firmware on a HP Proliant Microserver Remote Access Card installed in my N40L.
      Can someone please explain what I need to do to create a boot device that will update the firmware on the Remote Access Card?
      Tony Self
    • Joe_Miner
      By Joe_Miner
      I installed a BU50N Blu-ray 4K drive in my HPE ProLiant Gen8 MicroServer.  Worked out well, I'm using PowerDVD13 -- I had to restart the "Machine" several times before it saw the ODD but "Machine" finally figured it out.
