Joe_Miner
ESXi 5 on MicroServer?
2percenter
Hi, there is a compatibility list for hardware, just search for io devices and set the other filters as needed.
http://www.vmware.com/resources/compatibility/search.php?deviceCategory=io
Notbsure if the n40 supports passthrough, if so you could create the datastor on the internal sata connections and passthroughtthe controller to one vm. By doing so you will be able to use the controller for one big fileserver vm.
In regard to raid controllers, you can buy dell percs(5 or 6)cheap on ebay, check the compatibility list first. If youre keen in power efficiency, i recommend an adaptec 2405, this one can spin drives drown what not all raid controllers can, butis around 200 dollars and doesnt supportraid 5, if I remember correctly. Maybe the dell does.
On the other side you might like to check hyperv 2012, which might recognise your controller, inhave heard aboutbtweaks runing esxi in hyperv, or was that vice versa..
Good luck.
a15457
Yeah I've been through the compatability list ... Duh only after I'd already paid for the card. I was just after some recommendations given that there is only a small amount of space inside the N40L and would prefer to hear of some success stories before spending any more money ... my gf is going to kill me when I tell her I need to buy more computer bits.
Cheers.
Guest no-control
IBM m1015 for a RAID card is confirmed compatible with ESXi. Flash with LSI firmware and your good to go.
a15457
Thanks for the response no-control ... a quick bit of googling tells me though that the IBM m1015 doesn't do RAID 5 without an extra addon card. :(
Cheers,
DAVE
ImTheTypeOfGuy
HOw much do you want for that 2720?
goldleader80
I have been running ESXi 5 on the MicroServer no problems. My setup is as follows:
6GB of RAM
HP Smart Array P410 RAID Controller
1x 250GB for install of ESXi and for VMs hard disks
3x 1TB RAID 5 for storage for my NAS4FREE VM, also acts as a Media Streamer to PS3 and Torrent client
The HP Smart Array P410 can be picked up for around £100 on ebay, that's what i did. Real easy to install and setup and works straight out of the box with no fuss.
As for memory take a look here under the RAM section and people are saying the server will take 16GB of memory which I might have to upgrade to.
Loving this server got the £100 cash back so total cost for server, Raid card and memory was only about £250, already had the 3 x 1TB drives.
Also if you want to backup your VMs Veeam do a free version of their software that will take a full backup of a VM and also compress it. Doesn't do any scheduling but for a one off backup its very good, also you can restore the whole VM or just certain files if needed. Link
Edited by goldleader80
ikon
I find the built-in Task Scheduler works great for running almost anything.
a15457
Thanks GoldLeader80 onthe RAID card tip. I'll keep it in mind.
CablDeViL
I am having a problem getting ESXi 5.1 to boot from a USB stick. I guess its time to load up my old USB CD Drive.
jmwills
Try a different stick.
    • npapanik
      By npapanik
      FYI, I have just installed Windows Server 2019 Standard (Desktop Experience) using the latest (WS2016) HP AMD chipset & VGA driver. Everything is recognised in Device Manager and stable.
    • TonyTheTechie
      By TonyTheTechie
      I need to update the firmware on a HP Proliant Microserver Remote Access Card installed in my N40L.
      Can someone please explain what I need to do to create a boot device that will update the firmware on the Remote Access Card?
      Tony Self
    • Joe_Miner
      By Joe_Miner
      I installed a BU50N Blu-ray 4K drive in my HPE ProLiant Gen8 MicroServer.  Worked out well, I'm using PowerDVD13 -- I had to restart the "Machine" several times before it saw the ODD but "Machine" finally figured it out.
    • iwilltry
      By iwilltry
      Hi there,
      I hope this topic fits here just right.
      So a few days ago, I moved my Microserver Gen8 to a friend's place and resetted it.
      When we set it up with new disks, the raid-creation in OpenMediaVault (Debian 9.6) failed.
      `smartctl` tests passed just fine though and vendor-tools also didn't report any drive errors.
      What happened?
      - I start the Raid creation via `mdadm` and after a while (random blocks and times), it fails and the second disk seems to fail (e.g. sda and sdb are creating a raid, then sdb gets "kicked out" and reread as e.g. sdd, sometimes even with only a few GB of space instead of 3TB).
      I tried attaching the second disk on ata2 and ata3, but it keeps failing. The one on ata1 works just fine though.
      I tried different disks and vendors, but get the same results.
      There are some errors in `dmesg`, but I don't know what they mean. I pasted them here: https://pastebin.com/raw/XASQJ6cy
      What I did here: I stopped the raid to re-create it, but then didn't do anything for a while and the error still came up.
      Can someone help me with this? (As a wild guess, I'd say that somethings wrong with the SATA connections at least on ata2 and ata3).
      Thanks in advance
