biosblues
You should be able to repeat the procedure with the stock bios from HP. Does that not work?
I've tried, does nothing. The USB stick flashes a few times, and only when its in the onboard USB port, but otherwise nothing.
Are you saying the system doesn't display anything during POST?!?!
That is correct.
Edited by biosblues
  • Replies 557
    119
  • Joe_Miner
    62
  • jmwills
    46
  • cskenney
    24
Popular Posts
Hi Anttech,   I had the same issue and couldn't download it from the german site.   I found a mirror at the following address :   http://translate.google.com/translate?sl=auto&tl=en&js=n
Well I upped it to my dropbox. Please serve yourselves.   https://www.dropbox.com/s/qff7abgmt7hau6z/O41100113.ZIP Well I upped it to my dropbox. Please serve yourselves.   https://www.dropbox.co
Here are the two original versions that I have now posted in dropbox   http://www.dropbox.com/s/u6r1ogp2gt7ju1c/SP64420.exe?dl=0 http://www.dropbox.com/s/m1sisxxaa0oszoc/SP54344.exe?dl=0
Posted Images
That is correct.
Well that certainly seems abnormal. Like jmwills says, try to RMA it. I just hope HP doesn't give you a hassle because you tried to flash a non-HP-supplied BIOS.
biosblues
Thanks for all the help. I think I'm going to have to take your advice on this one and just do a RMA.
Hi,
I've got my microserver few days ago. I would like to flash with the modded firmware from the first post but my microserver is connected with my tv and after startup I got a message from the tv which told me that the video mode is not supported.
Is there any way to force bios update without any interaction?
I would find that a bit risky. Personally, I would find a real monitor, somewhere, somehow, and connect it to the server.
I agree. Even if you managed to get the BIOS to flash unaided, which is possible, I very much doubt the flashing process would make the picture appear on the monitor. Deffo get a momitor and do it !
hp bios are trash
Hello folks I'm new here as you can tell. Let me start off with a small introduction. My name is Larry I know some things when it comes to computers but not near as much as most here. I REALLY need help on getting my bios to show the "shadowed" aka hidden BIOS options. I have a HP Pavilion dv9008nr Notebook PC
Serial Number: CNF6453S0T
Product Number: ez458ua
I want to turn my fans on before my system reaches overheating temps (why would anyone set the fan this way), change my video settings and a few other things. But the most important things I need to know how to do is fix when my fan comes on and my video options. I have looked for weeks and stumbled on this and you guys give me lots of hope again ! PLEASE please I BEG of anyone who is willing to help out a rookie, I have never did anything with BIOS. If there was anyway I could help you fellas out I honest to God would but lets be honest you know more than I do so I'm no use. We can chat here or I'll be more than happy to chat with any messenger you like. Thanks in advanced.
(I'm glued to this page for the time being lol)
jmwills
There is a great post by forum member "Joe_Miner" where he goes into the BIOS modification in depth. Other posts by member "Diehard" are also excellent reference guides.
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
