Perfect, thank you for the screen shots.
I have two RAID 1 disks configured on my microserver will updating the BIOS cause any problems with the RAID configuration?
Also another question about the RAID configuration on the microserver, is the onboard RAID controller a software based controller or hardware based, and if it's software based is it any better than the mirror ing that I could set up in Windows disk manager?
  • Replies 557
    119
  • Joe_Miner
    62
  • jmwills
    46
  • cskenney
    24
Popular Posts
Hi Anttech,   I had the same issue and couldn't download it from the german site.   I found a mirror at the following address :   http://translate.google.com/translate?sl=auto&tl=en&js=n
Well I upped it to my dropbox. Please serve yourselves.   https://www.dropbox.com/s/qff7abgmt7hau6z/O41100113.ZIP Well I upped it to my dropbox. Please serve yourselves.   https://www.dropbox.co
Here are the two original versions that I have now posted in dropbox   http://www.dropbox.com/s/u6r1ogp2gt7ju1c/SP64420.exe?dl=0 http://www.dropbox.com/s/m1sisxxaa0oszoc/SP54344.exe?dl=0
Posted Images
jmwills
Not saying that it will, but I would check the consistency of the array after you mod the BIOS. If this were an approved procedure from HP, I would have no worries, but since this is a hack, I'd check the array afterwards.
If it's like every other mobo-based RAID I've seen, it's a hybrid between hardware and software. One disadvantage of it is it's very unlikely it could be moved to another box if the mobo fails; with add-in RAID cards this is usually possible. It's also often possible with Disk Manager based RAID. You can normally just import the array into the new Windows box.
jmwills
One of those links should tell you. From memory, I think the N36L is also good to go but look at the documentation in the links.
Thanks for clarifying the situation; I'm sure it will help a lot of people in these forums. if you still have some of those links you found, I'm sure others would be grateful if you posted them.
  • 4 weeks later...
jazzerjay
Looks like only 1 drive is visable from the Sans Digital TR4M, so it's as if it's a regular single hard drive connected externally. Bummer. :( Looks like I would have to install a esata port multiplier card in the PCIx slot.
At least the DROBO-S is visable as 1 drive, but that's a premuim device.
I cannot believe I missed this post. I jumped on that Shell Shocker and figured I'd be good to go. Now I'll need an esata port multiplier card. This one is all on me though. Thanks John!
  • 4 weeks later...
biosblues
Hi, Hope someone can help me, seems I've bricked my N40L.
I followed all the instructions regarding the BIOS mod update, but after getting to the C:\ prompt and doing the restart my server is basically dead.
On power up the HP logo turns red for a second and then goes out, the power button is green, fans are all on, but the screen is just black?
Any idea what i could do to recover the factory BIOS or any other BIOS? I even tried doing the CMOS clear procedure by changing the jumpers on the board.
Any help would be appreciated.
jmwills
biosblues
Get a copy of the BIOS form the HP site.
http://h20566.www2.h...achetoken#12212
Thanks, but I've tried this.
When using the USB stick, are you supposed to use the on board USB port?
What i don't understand is when I ran the mod, I could see it was doing something because of all the output to the screen. It did not take long until I saw the C:\ prompt, I removing the USB stick and did the restart. What is the actual procedure for powering down when you get to the prompt, hold the power button down till it turns orange or pull the plug?
I've followed the following forum too, but with no luck.
http://h30499.www3.hp.com/t5/ProLiant-Servers-ML-DL-SL/BIOS-recovery-Proliant-Microserver-N36L/m-p/4726699#M107808
Is there any way to get back to factory defaults?
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
