  • Replies 557
    119
  • Joe_Miner
    62
  • jmwills
    46
  • cskenney
    24
Popular Posts
Hi Anttech,   I had the same issue and couldn't download it from the german site.   I found a mirror at the following address :   http://translate.google.com/translate?sl=auto&tl=en&js=n
Well I upped it to my dropbox. Please serve yourselves.   https://www.dropbox.com/s/qff7abgmt7hau6z/O41100113.ZIP Well I upped it to my dropbox. Please serve yourselves.   https://www.dropbox.co
Here are the two original versions that I have now posted in dropbox   http://www.dropbox.com/s/u6r1ogp2gt7ju1c/SP64420.exe?dl=0 http://www.dropbox.com/s/m1sisxxaa0oszoc/SP54344.exe?dl=0
Posted Images
Yes cskenney you are correct this installs the default HP BIOS. I have played with a few variants of the MOD BIOS but have gone back to the factory default for personal reasons. To add an addendum to the above instructions I left you should . . . .
6. Copy the MOD BIOS (I think the file is O41_AHCI.ROM) to the root of the pen drive.
7. Look for the file flash.bat in the root of the pen drive, right moise button and select edit.
8. The file will open in Notepad by default with a line like this: kbd /"flash O41072~1.rom -r 100000,10000 -r 1e0000,10000;q"
9. You need to change the name of the BIOS file in the batch to the new name. In this example: kbd /"flash O41_AHCI.ROM -r 100000,10000 -r 1e0000,10000;q"
Sole people prefer to change the file name of the BIOS and drop it into the root of the Pen Drive. While this works you can loose which BIOS is which after a while so I perfer to work with the actual file names given by the author. Just my way . . . :rolleyes:
Whatever the modified bios is you can always just keep dropping the *.ROM file into the root of the pen drive and amending the file in the batch file accordingly. Save a pen drive for this job now they are cheeper than chips! (fries for you guys over the pond) :)
MarkJohnson
Here's a link to my SkyDrive for the USB software. You have to go get the modified BIOS.
https://skydrive.liv...368D1A96947!169
well, I downloaded the file. extracted it, copied it to the SWSetup/SP52016/USB Key and ran HPQUSB and flashed it. but it came up with a o41 bios screen but had a new date, but when I went into the BIOS it was exactly the same and no Chipset menu?
Is the BIOS file corrupt? I renamed the BIOS file to the one in the USB Key folder and gave permission to copy and replace the old one.
Not 100% sure I did this right as my allergies are acting up and I have a migraine which makes it hard to focus, so maybe I made a mistake.
Can anyone verify the BIOS is the new AMI-BIOS-MOD in first post is correct? It has a filename of O41011711.ROM when I extract it.
-=Mark=-
yodafett
-=Mark=-
you still need to go to the link at the beginning of the thread and download the bios from like the 4th line on the bios mods thread and then rename it to replace the file on the USB
MarkJohnson
Thanks yoda, I was using the first link before.
Boy, there are sure a lot of new menu/settings. It looks like a few don't even belong (USB 3, Audio, Atheros NIC, etc)
Things sure seem a bit faster too. I was getting worried as the 8GB upgrade didn't help much. Nice that the BIOS helpped out.
Thanks again for everyone's help
-=Mark=-
Edited by MarkJohnson
Does the modified bios have any options to enable the different sleep modes (s1, s3) that the AMD chip set supports, but HP does not allow access to?
NetCaptive
Here's the only options i see:
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
