diehard
Steven Bell
hi guys im new to the home server show but seen some off your long videos on YouTube even the one where your N54L failed to install windows server thanks to the nic
why im here is im using my old N36L and never ever had any problems with it im running windows server 2012 essentials on it with 0 problems
and want to use it as a test bed for windows server 2016 essentials just to see how well i can get it to work im looking at buying the newer Gen10 server but as the old one runs well and cant ever see my self replacing it i do have the SP64420 bios installed and as im out of warranty i dont know if there is a new bios but do know there is a mod for it so does anyone know where i can lay my hands on the most up to date modded bios so i can install it and when the new server comes i can start doing some testing all the links i keep checking says there is no files to download like there taken away
any help would be grand and keep up the good work you guys do
kind regards steven
Edited by Steven Bell
kalatopas
@Steven Bell almost a month later, but as I just did the update I would like to share this page with all for anyone that trying to find the latest moded bios!
here it is: http://www.nathanielperez.us/blog/hp-proliant-n40l-bios-modification-guide
In the comments, they say that support even N36L so you can safely install it! :)
Edited by kalatopas
Alex Maleta
Hello. I am the owner of HP ProLiant N40L MicroServer. But nowhere can I find the bios sewing. Please share links to the latest versions. Thank.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
    • felt
      By felt
    • nlitend1
      By nlitend1
      I upgraded 2 identical systems (both running windows 7) to SSDs and restored images via WHS 2011 and noticed that one of the systems is not running AHCI mode (according to AS SSD benchmark and device manager). I made the 2 registry changes already in windows according to this guide....
      http://www.sevenforums.com/tutorials/61869-ahci-enable-windows-7-vista.html   I then made sure that the BIOS had SATA configured as AHCI (and not IDE). After reboot, I did not get prompted to install the AHCI drivers and the performance is significantly less with the system that appears to be running in IDE mode.   The following are two strange things:  1. Changing the BIOS setting to AHCI or IDE never gives me a BSOD. 2. Stablebit scanner states that both TRIM and NCQ are both working on the SSD and from what I can tell NCQ cannot run without AHCI mode.   This system apparently appears to be "stuck"... in what appears to be IDE mode...Any ideas on what to try at this point? Am i looking at a clean install or even worse... corrupted BIOS?    Thanks!   nlitend1
