Indeed I saw that, I must have d/l'ed the Tobi mod the other day, however it does read still in the BIOS as:
O41
10/01/2013
the actual date stamp of the BIOS rev vs release date (15 NOV 2013) I assume was throwing me off.
  • 1 month later...
  • Replies 557
    119
  • Joe_Miner
    62
  • jmwills
    46
  • cskenney
    24
Popular Posts
Hi Anttech,   I had the same issue and couldn't download it from the german site.   I found a mirror at the following address :   http://translate.google.com/translate?sl=auto&tl=en&js=n
Well I upped it to my dropbox. Please serve yourselves.   https://www.dropbox.com/s/qff7abgmt7hau6z/O41100113.ZIP Well I upped it to my dropbox. Please serve yourselves.   https://www.dropbox.co
Here are the two original versions that I have now posted in dropbox   http://www.dropbox.com/s/u6r1ogp2gt7ju1c/SP64420.exe?dl=0 http://www.dropbox.com/s/m1sisxxaa0oszoc/SP54344.exe?dl=0
Posted Images
Hello
I downloaded and installed the o41100113-acpi-s3+s4_hotplug_fan-control.rar file. I got lot of new menu, but i have two problems:
1: on the main screen i see that the BIOS ID: 041, Bios Version 07/29/2011.
2: on the disn menu i doesn't see my disks. All of disks are non detected, but i see this on the boot menu where i can select the boot disk.
So this  is the latest modified bios? And that is normal that i didn't see any disks in the bios?
laca
  • 3 months later...
Hello,
I recently got a HP Microserver N40L and find it to be very noisy to setup in my Living Room so i bought a Noctua PWM Fan without realising that the Server needed a specific FAN Speed to Boot up.
Can the modded BIOS get around this Limitation?
  • 2 months later...
Has HP now blocked this fix from working on newer N54L stock, because ......... I'm not too damned happy :/
This is my OLD HP Microserver, you can clearly see an option for "OnBoard PCI IDE Controller", this option is MISSING on my new server :/
You can also see, when it does disk detection
All 6 hard drives are visible under AHCI.
On my new Microserver, the PCI IDE option seems to be locked in IDE mode (because the option is ENTIRELY missing)  and it only detects 4 AHCI disks and 2 IDE disks.
I'm 99.976% sure the hacked ROM was installed correctly by me, because the incredibly complex, weirdo options to the far right are there (very extensive north / southbridge menus, which I distinctly recall NOT being there on the stock ROM for the Microserver series)
Am I doing something wrong or was a change recently made?
Edited by wizzbang
  • 4 weeks later...
Hi All,
I am currently running BIOS version o41072911, what is the latest modified version available?
Could someone also let me know if there is any benefit to updating the BIOS?
I am running additional hard drives in the optical bay and I don't fancy playing with all the BIOS settings all over again if there is no real reason to update the BIOS.
Thank you
  • 5 months later...
  • 5 months later...
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
