  • 6 months later...
  • Replies 557
    119
  • Joe_Miner
    62
  • jmwills
    46
  • cskenney
    24
Popular Posts
Hi Anttech,   I had the same issue and couldn't download it from the german site.   I found a mirror at the following address :   http://translate.google.com/translate?sl=auto&tl=en&js=n
Well I upped it to my dropbox. Please serve yourselves.   https://www.dropbox.com/s/qff7abgmt7hau6z/O41100113.ZIP Well I upped it to my dropbox. Please serve yourselves.   https://www.dropbox.co
Here are the two original versions that I have now posted in dropbox   http://www.dropbox.com/s/u6r1ogp2gt7ju1c/SP64420.exe?dl=0 http://www.dropbox.com/s/m1sisxxaa0oszoc/SP54344.exe?dl=0
Posted Images
  • 4 weeks later...
Question for the sake of clarity, I believe I read this on here but cannot seem to find the post (needle) in the forum (haystack). I flashed a G7 N54L with the MOD-BIOS so it sits at 041 -10/01/2013. I've made the adjustments I want and now I want to install W8.1 Pro for an htpc build. Seems I now need to create another flash drive using SP64420.exe and this will flash it to the latest HP factory BIOS correct? When I do this, it will essentially lock the hidden mods again, but leave them in the state I have adjusted to, but allow the onboard NIC to function correctly with Server 2012 and Windows 8?
Also, is there a list of non-functional items the BIOS-Mod seems to enable? i.e., I notice that it enables an NEC USB3.0 on-board controller but as far as I can tell this doesn't exist? Also I saw mention somewhere that someone had slipped in an SLIC 2.3 mod somewhere too? What exactly does this enable?
Thanks!
Edited by Helzy
Joe_Miner
When I flashed with the factory SP64420.exe the BIOS flash returned my eSATA and ODD SATA ports (Ports 4 & 5) to IDE emulation mode (i.e. everything was reset to "factory" state).  YMMV.  You will need SP6440.exe (or its MOD version -- check the stickies for links to the Tobi MOD, YMMV) to run Win 8.1 or S2012R2 on the MS.
NOTE: I've had no experience with the Tobi Mod so use it at your own risk.
Edited by Joe_Miner
OK So I read that incorrectly. What is the date stamp on the HP factory BIOS from SP64420.exe?
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
