diehard
Louie
I just want to thank everyone for information on the BIOS update. I thought I had screw up when my nic was not working. Until I found this post and read threw all the post on here. I then found out I had to download a different rom file and BAMMM my network card started working once again. It had taken me almost 3 days trying to find some good information on this.
Thank god there was google and this forum for pointing me in the right direction.
Now I need to find out about memory upgrade and installing drives on my machine... lol...
Just started playing with this mini server since I had it for about 1 yr...
Thank you guys once again.
ikon
Welcome to the forums Louie. I think you'll find this is a great, friendly community.
gegenator
Hello everybody.
At first, i'm sorry for my verry poor English, but i'm French !
Well, i have a N40L since two years. It run very nice, but i want to install W8 on it.
But i discovered that not run with the originally bios...
But now, the new bios from HP that seems to correct this problem is only available with a warranty (mine have 2Y !).
Is anybody coold help me by giving me a provisory link to download the necessary ?
I'ill be verry prood to you.
Thanks.
Edited by gegenator
adobo
We have discussed this many times. The N40L was only made for 8GB of RAM. Some have been successful getting 16GB to be recognized but others have had mixed results (like you). There is nothing to set to force it.
...does this bios version enable the hot-swappable hdd bays?
Joe_Miner
While you can enable it in BIOS the hardware does not support hot-swappable
jmwills
The thread that just keeps on giving!
ikon
Hence why it was hidden. I almost wish the modders had left this feature hidden.
Joe_Miner
If you want to use the Port Multiplier drivers you will need to enable it in the BIOS even if the HW doesn't actually support it.  That's why you wouldn't want it hidden.
AxlxA
Hi everyone, I'm brand new here.
I just received my new N54L today and attempted to do the mod bios flash.
The sequence was as described:
1) Booted up vanilla server with VGA LCD, usb keyboard/mouse --> Hit F10 and went into bios. Ver was O41.
2) D/led and installed the flash tool. Extracted the modded bios with the lower case o41...., replaced the original on the usb.
3) USB into server, booted up nicely and POST. See a bunch of random symbols going across screen, within a minute, I see c:\>.
4) Removed USB
At this point, I shut down the server and started it back now. Now the trouble....
Server powers on with GREEN power button. No HP logo light. no video, no POST beep or anything. Fan still spinning at full speed.
Powered off -> power on again same ordeal.
Powered off and unplugged from power outlet -> change cmos jumpers to reset -> powered on, waited a few minutes -> powered off -> cmos jumpers back to normal
Now when plugging in the power cable, server powers on right away without me pressing power button. now HP LOGO flash blue once and turns a solid RED.
At this point, I redid my USB flash drive with original HP bios. Plugged it into server, powered on. still no video, no POST, waited 10 minutes with factory bios USB.
Powered off and rebooted, still same no video, no POST, nothing's happening except fan spinning, HP logo red, power button green.
I even tried reseating ALL the plugs, and even switched the original RAM slots. Still stuck...
Please help?
(did not add any new PCIe, HDD, or any ram. The only thing that were ever plugged in were USB flash drive, USB keyboard/mouse, and VGA to LCD.
I'm very worried I have some major hardware fault and can't salvage this server.
ikon
I'm a little confused. Are you saying the Port Multiplier feature is only available to be enabled if you first enable Hot Swapping?
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
    • felt
      By felt
    • nlitend1
      By nlitend1
      I upgraded 2 identical systems (both running windows 7) to SSDs and restored images via WHS 2011 and noticed that one of the systems is not running AHCI mode (according to AS SSD benchmark and device manager). I made the 2 registry changes already in windows according to this guide....
      http://www.sevenforums.com/tutorials/61869-ahci-enable-windows-7-vista.html   I then made sure that the BIOS had SATA configured as AHCI (and not IDE). After reboot, I did not get prompted to install the AHCI drivers and the performance is significantly less with the system that appears to be running in IDE mode.   The following are two strange things:  1. Changing the BIOS setting to AHCI or IDE never gives me a BSOD. 2. Stablebit scanner states that both TRIM and NCQ are both working on the SSD and from what I can tell NCQ cannot run without AHCI mode.   This system apparently appears to be "stuck"... in what appears to be IDE mode...Any ideas on what to try at this point? Am i looking at a clean install or even worse... corrupted BIOS?    Thanks!   nlitend1
