diehard
Joe_Miner
It would be the exact same process as in HP ProLiant N40L MicroServer Build and BIOS Modification Revisited with just the newer BIOS.  Be sure to prepare extra copies of the Stock BIOS as indicated in the Blog in case things go wrong.
I haven't used the new "Mod BIOS" but I have flashed the Stock SP64420.exe several times in order to run Win 8.1 and Server 2012 R2 and it flashed the same as the previous.  I would suggest preparing several Flash drives -- I found in HP ProLiant MicroServer BIOS Flash with SP64420 that of 5 different Flash drives I tried two wouldn't work.
You don't really need to disconnect all the hard drives before flashing but the fewer things you have installed/hookedup/etc the less time it takes to boot up do all it's internal checks/handshakes and do the flash (but even then it's only "sec's" and only makes a difference if there's a power outage during the Flash).  YMMV.
Edited by Joe_Miner
ikon
I agree with Joe_Miner in that you probably don't need to remove the drives to flash the BIOS, but I would do it just to be safe.
sebus05
Hi,
found a modded version of the latest bios (not verified yet).
Will binary compare first and try to reproduce the AMIBCP patch (if I can ;- ).
Link (in German) http://www.hardwareluxx.de/community/f101/hp-proliant-n36l-n40l-n54l-microserver-752079-430.html#post21503128
Cheers,
Jens.
So this mod works? Strange, as the guy made a mistake & made it definitely with corrected bootblock checksum (which is not to be done on this BIOS)
sebus
cosote
sebus
Yes, running fine since then
sebus05
I did add Slic 2.3 to it & gave it a try today (have G8, so can "risk")
Running fine, but all the options unlocked are pointless as many simply do not apply to the hardware...
sebus
ikon
Not ALL the options that are unlocked are pointless. Yes, some of them, maybe even many, do not apply to the hardware, but some of them do apply. That's why people do it.
sebus05
It should read: "ALL the option unlocked are pointless (not all options are pointless, pointless is to have them unlocked all), only SOME should be unlocked (one that relate to the actual hardware)"
ikon
OK, but the guy who unlocked them did it for free, on his own time. I, for one, wouldn't look a gift horse in the mouth.
karmantyu
Hello Joe_Miner,
I would suggest a slight modification to your well respected article http://homeservershow.com/hp-proliant-n40l-microserver-build-and-bios-modification-revisited.html.
You are stating "Depending on your planned setup you may not want to Disable SATA IDE Combined ModeLoneWolf found that disabling SATA IDE Combined Mode also disable the ability for the MicroServer to see his HP Smart Array P410 Hardware RAID controller. YMMV." which is very likely correct, but missing the point that enabling SATA IDE Combined Mode means that channel 0 and 1 (ODD tray) will function as ATA channels thus limiting transfer rates on them to 150.000MB/s.
ahci0: AHCI v1.20 with 4 3Gbps ports, Port Multiplier supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
atapci0: <ATI IXP700/800 UDMA133 controller> port 0x8000-0x8007,0x7000-0x7003,0x6000-0x6007,0x5000-0x5003,0x3000-0x300f irq 17 at device 20.1 on pci0
ata2: <ATA channel> at channel 0 on atapci0
ata3: <ATA channel> at channel 1 on atapci0
ada_: 150.000MB/s transfers (SATA, UDMA6, PIO 8192bytes) for channel 0 and 1
ada_: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) for rest of the channels
This will be not a limiting factor for conventional HDD's but impair SSD performance for sure. So when enabling SATA IDE Combined Mode is set, make sure SSD is attached to the front ports and not to the ODD or eSata ports.
disabling SATA IDE Combined Mode results:
ahci0: AHCI v1.20 with 6 3Gbps ports, Port Multiplier supported
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
ada_: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) for all of the channels
ikon
It likely will impair performance of SATA III drives as well, depending on which drive it is.
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
    • felt
      By felt
