diehard
Since I don't have a microserver, I'm curious. That isn't really an x1 slot is it? Doesn't it have an extra connector space behind the x1 portion? I just looked at a photo of the card and, if it's the same card, it looks like that extra connector portion is where the magic happens :)
it is an x1 slot with a secondary bus connector behind it that disables the built in video and access to the lower bios functionality
at home i have a Dual Port x1 NIC pluged into mine teamed up for a 2gbs iscsi link
I agree. I am sure the SATA card will work in the X16 slot. I just moved the remote access card over to test it. Wish I hadn't wasted the time now !
Waiting for the Controller card to turn up !
Edited by mR JoLLy
Just to clarify, the secondary bus connector disables onboard video and enables lower bus functionality, is that correct? If so, it sounds like the RAC pretty much redirects video calls from the onboard to the remote user.
correct with the RAC installed you use the video port on the RAC and not the original port on the motherboard, but you also can now power up, get smnp messages, access the bios for a nice headless server.
I know this is sending this thread off topic a little so apologies for that. The SMTP messaging from the card only works with unsecured gateways which is a pain as all my e-mails need passwords to send these days thanks to the SPAMMERS! The nice thing about it is you can set the remote computers DVD ROM and drives as virtual peripherals for the server. Not set it up yet but it looks straight forward enough :rolleyes:
I won't ever attach a monitor to the box but the video is diverted to the new port on the card. All good fun!
Use this link to create the bootable thumb drive http://cvscorp.homes...ey%20Media).exe but replace and rename the BIOS bin file with the one from BIOS-MODS.
You should only have to reboot the server with the thumb drive and it will do all the work.
Look under the tab for Southbrige stuff there is a lot of stuff there. That's where I found stuff for the ESATA port to recognise my DROBO.
Is there an alternate link. This has been down since Thursday. and I can't figure a way to install the BIOS. HP has BIOS file as an .exe
-=Mark=-
I have just done this for the first time on my New Microserver so just follow these steps:
1. Download the BIOS file from the HP Website. The latest BIOS file is (I think) SP54344.exe.
2. Double click this file and it will want to extract. The default is in the C:\ drive but I chose a new folder to extract it in on the desktop. As long as you know where it's extracted then that's all good. But don't extract to a pen drive yet!
3. When the extract is finished it will open a web page. You can follow this if you want but it's not necessary so close the browser session.
4. Open Windows Explorer and insert your pen drive into a spare USB Slot. Check you have no valuable files on the drive as they are going to all get deleted! You have been warned!!
5. Go to the location in Windows Explorer where the files were extracted. You will see some files in the root and some folders: Flat Files : Start_Files : USB Key. Go to the folder "Flat Files" and in there you will see a file called HPQUSB.exe. Double click to execute the "HP USB Key Setup Creation Utility" which should detect your pen drive for configuration. If you have more than one pen drive connected I suggest you choose from the pull down menu carefully. Remember all files on the target will be deleted! Select "Start", accept the warning about overwriting the data and it will do the business on the pen drive.
6. What you need to do then is to go to the folder USB Key that was originally extracted and copy all of the files in that folder. Paste them into the root of the newly prepared pen drive. It will prompt about overwriting files, simply say "Yes to all" and the new BIOS files will be added to the pen drive.
Don't ask me why it's done like this but it is!
It's then a matter of putting it into the pen drive of the server and booting. By default the server is set to give boot priority to the USB pen drive so it should do the business from there.
Your instructions are close but not exactly how I did it. I also used the BIOS update from the HP site. However, you didn't include any instructions above about replacing the .ROM file with the one from BIOS-MODS. I am not at home right now so I don't want to guess on the steps I took. If no one else chimes in I will add to this post later.
Your instructions are close but it is missing the modified BIOS step.
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
