diehard
Trig0r
I understand that.
And the last part is what is confusing: There really is no single source that has clearly the latest BIOS.
Noone is criticizing them at all, Im just stating that a mod could update the first post with the latest information as long as, like cskenney said, the latest information can be found.
IMHO, someone should take ownership of this info, cut it to a single post with the stock BIOS and modded BIOS in a single post, lock it, sticky it.
/Job
Guest Micco
Hi,
I really would like to install "Windows Server 2012 R2 with Update" on my N40L, but I probably need the latest BIOS update.
I'm having troubles downloading "System ROMPaq Firmware Upgrade for HP ProLiant MicroServer (For USB Key-Media)" from HP's website, can someone help me get the following software?
Type: BIOS - System ROM Version: 2013.10.01 (A) (15 Nov 2013)
File name: SP64420.exe (2.6 MB)
SOFTPAQ NUMBER:  SP64420
FILE NAME:  SP64420.EXE
TITLE:  System ROMPaq Firmware Upgrade for HP ProLiant MicroServer Servers (For USB Key-Media).
VERSION:  2013.10.01A
LANGUAGE:  English
ROM FAMILY: O41
REVISION: A
PRODUCTS AFFECTED:  HP ProLiant MicroServer Servers
OPERATING SYSTEM:  All
EFFECTIVE Date:  11/16/2013
SUPERSEDES:  sp54344
Do anyone know if there could be any issue with installing the above software when I'm using diehards modified bios?
Edited by Micco
ikon
In most cases with typical HDD's it's not going to make much difference but you are correct that with the BIOS-MOD you can turn-off IDE emulation move on SATA Ports 4&5 (i.e. the eSATA Port and the ODD SATA port on the System Board) and then get the higher SATA II 3Gb/s speeds on those ports.  You're only going to notice the speed improvement with high performance drives like the ST3000DM001 or any of the 6th Gen VelociRaptors or a SSD.
This was tested on both the 4 & 5th ports http://homeservershow.com/forums/index.php?/topic/5752-performance-improvement-on-odd-sata-port-contributed-by-bios-mod/
So, bottom line, if you want the higher thru-put for Ports 4&5 you'll want the BIOS-MOD
Thanks Joe. I didn't want to say for sure I recalled it being for both ports 'cause these old brain cells aren't as agile and reliable as they once were ;)
riahc3
I have the modded BIOS as well as the original HP file on my dropbox...
Is it the latest one? What is your dropbox?
Suggestion is noted and makes sense. I will see if I can sort through the various posts and identify the information that is most relevant.
Thanks a lot :)
/Job
I completely agree. This would have the plus side of also bringing more traffic to HSS for more revenue since it has the latest info/BIOS :)
Trig0r
Think its the latest one yes, only grabbed it from here a few weeks ago..
HP BIOS
https://www.dropbox.com/s/az6edqu9zedm3tk/SP64420.exe
Modded BIOS
https://www.dropbox.com/s/8tzq1f88nek6e14/O41100113.ROM
Not sure on the legalities of HSS hosting or promoting a file thats only meant to be available on Hp's site to people that have paid for a carepack etc..
Not sure how long it'll last as the last time I hosted stuff publicly my account got frozen :D
I do have an FTP server though that I could stick it on...
riahc3
HP BIOS
Modded BIOS
Well, technically, HSS is not hosting it....Dropbox is.
And thank you; Im flashing the modded one as soon as I get home.
Edited by riahc3
Trig0r
yeah but you were on about HSS profiting from it, that'd be an issue I would of thought.
ikon
Certainly I could see HP getting upset if HSS profited from hosting their files.
unmesh
I've been using the mod of sp54344 successfully for a while now and recently upgraded to the mod of sp64420 in order to play with Server 2012 R2. I now find that I can boot an OS off USB and it sees the hard drives in the bays (including ports 5 and 6) but the BIOS itself does not "see" any of the drives themselves.
I suspect I've done something stupid in the settings based on my understanding of how to mod the SouthBridge settings in the newer BIOS menu and was hoping someone could point out the error.  My settings are:
Chipset->SouthBridge Chipset Configuration->SB SATA Configuration->
OnChip SATA Channel [Enabled]
OnChip IDE Type [iDE]
SATA IDE Combined Mode [Enabled]
PATA Channel Config [sATA as Primary]
SATA ESP on all PORT [Disabled]
SATA Power on all PORT [Disabled]
Thanks.
Edited by unmesh
phoenix73
Quick question.
I just received N54L and didn't yet updated its BIOS, so I think it's still the 2011 revision.
Installing SP64420.exe and replacing O41100113.ROM in USB key by modded one is enough ?
No need to install SP64420.exe with original ROM before ?
I read some advices to disconnect all hard drive before flashing, is it correct ?
Thanks for your help
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
    • felt
      By felt
    • nlitend1
      By nlitend1
      I upgraded 2 identical systems (both running windows 7) to SSDs and restored images via WHS 2011 and noticed that one of the systems is not running AHCI mode (according to AS SSD benchmark and device manager). I made the 2 registry changes already in windows according to this guide....
      http://www.sevenforums.com/tutorials/61869-ahci-enable-windows-7-vista.html   I then made sure that the BIOS had SATA configured as AHCI (and not IDE). After reboot, I did not get prompted to install the AHCI drivers and the performance is significantly less with the system that appears to be running in IDE mode.   The following are two strange things:  1. Changing the BIOS setting to AHCI or IDE never gives me a BSOD. 2. Stablebit scanner states that both TRIM and NCQ are both working on the SSD and from what I can tell NCQ cannot run without AHCI mode.   This system apparently appears to be "stuck"... in what appears to be IDE mode...Any ideas on what to try at this point? Am i looking at a clean install or even worse... corrupted BIOS?    Thanks!   nlitend1
