diehard
Trig0r
The HP MS G8 only has 7 SATA ports (the 7th is reserved for CD drive, but also can be used otherwise).
Am I going blind, have only seen 1 SATA port on mine not including the 4 drive bays, where are the other 2?
Patschi
Oh, I'm such an idiot... Ofcourse there are only a total of 5 SATA ports... Somehow I typed the wrong number in. Sorry for the inconvenience!
Trig0r
Damn it, got excited then thought there were some tucked away somewhere :lol:
ikon
You don't actually need the original HP BIOS file itself. What you need is the flashing tools. You also need to name the modded BIOS file correctly, so the flashing tools can find it.
Essexraptor
Thanks - But where can I now get the original latest HP BIOS I need for it ?
Look in post #1..... Diehard has kindly made the bios available via his skydrive. Download and save !!!!
Edited by Essexraptor
Warlord1981
Hello there, thank u for your hard work ive been having my server with your modded bios since the moment i bought it. now i have to sell it though and i was wondering how do i flash back the original BIOS, because i dont want the new owner to have any problems with warranty etc.
thank you :)
Warlord1981
I downloaded sp64420.exe and followed the instructions here:
but when system enters syslinux and tried to run rompaq it gives the error: command or filename not recognized.
the microserver currently has the first modded bios.
jmwills
Di you by chance rename the rom?
ikon
As I mentioned above, it's critical to name the ROM file correctly or the flashing program won't be able to find it.
satego
Mhh sorry but on the Skydrive from DieHard - there I only see the SP54344 .... But isnt the latest something with SP64..... ?
Hi all,
sorry again me .... Its really a bit confusing - Or I am too stupid.....
Quick question - for the N54L - Is it the same MOD Bios from Dia Hards Skadrive or is there an otherone to be used ?
(I just got a cheap offer for an N54L and I will upgrade)
Thanks a lot
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
    • felt
      By felt
    • nlitend1
      By nlitend1
      I upgraded 2 identical systems (both running windows 7) to SSDs and restored images via WHS 2011 and noticed that one of the systems is not running AHCI mode (according to AS SSD benchmark and device manager). I made the 2 registry changes already in windows according to this guide....
      http://www.sevenforums.com/tutorials/61869-ahci-enable-windows-7-vista.html   I then made sure that the BIOS had SATA configured as AHCI (and not IDE). After reboot, I did not get prompted to install the AHCI drivers and the performance is significantly less with the system that appears to be running in IDE mode.   The following are two strange things:  1. Changing the BIOS setting to AHCI or IDE never gives me a BSOD. 2. Stablebit scanner states that both TRIM and NCQ are both working on the SSD and from what I can tell NCQ cannot run without AHCI mode.   This system apparently appears to be "stuck"... in what appears to be IDE mode...Any ideas on what to try at this point? Am i looking at a clean install or even worse... corrupted BIOS?    Thanks!   nlitend1
