diehard
imran
I just want to share: The new BIOS version from 11/01/2013 by "Tobi" works without any problems. Windows Server 2012 R2 is now booting fine.
Is Tobi's mod in English? Thanks
Patschi
He just changed some HEX values from the official HP-BIOS, which is available in some languages (don't know which yet) - but English is definelity one of them. So, yes, it's also in English.
satego
Hi all,
well I had i´nstalled the BIOS MOD over 1 year ago somewhere end of 2012, and it worked fine - have 6 HDDs in my N40L running and did not do anything on the BIOS since then.
Now I see there were BIOS updates by HP in the meantime and do I understand it correct also a NEW MOD Version of these new HP BIOS ?
But as I remember correctly even if I find the NEW MoD BIOS (which version is the latest and where can I find it ?) , I also need the latest HP original BIOS ???? ( I dont remeber how the installation worked) ??
BUT, on the HP site I can no longer download updates without this service contract ??? where can I then get the original HO Bios I need to install the latest MOD Bios ??
Thanks for some help !
Patschi
I'm sure that on the web are enough tutorials how to flash a new BIOS. Sadly I also can't remember how I did it on my old G7 - using now G8.
You can download the modded BIOS from Tobi here (2013.10.01 (A) (15 Nov 2013)):
http://www.share-online.biz/dl/CQTJ55XMZ4DY
(md5 checksum: bd236213538d7eed10eb6ef5c3b2a6f4
Edited by Patschi
satego
Thanks - But where can I now get the original latest HP BIOS I need for it ?
Patschi
Why do you want the original BIOS from HP? I thought your goal is to flash the modded one.
satego
When I read the instructions I found to flash the MOD BIOS - I understood that you need the original HP one to copy the .ROM file into this....but maybe I got it wrong.
By the way one other question as you just mentioned you now use the G8 - Is there also the possibility to enable or use 5 or 6 SATA ports like with teh N40L ?
(For SSD and 5 HDDs). Also which operating system you are using there ?
Edited by satego
Patschi
Can't imagine that you need the official BIOS for flashing a modded one... But maybe you need it.
That's a good question, but sadly I also can't tell you that. I'm using a hardware raid controller (HP Smart Array P420), which already offers me to use 8 drives at maximal speed, so I didn't ever care about. The HP MS G8 only has 7 SATA ports (the 7th is reserved for CD drive, but also can be used otherwise). I'm using VMware ESXi 5.5.
satego
Ok thanks - then maybe someone else can confirm if I need the original HP BIOS or not (in the meantime I think just the original FLASH TOOL to be used and on The OnerDrive account there was one with teh "old" MOD BIOS - so maybe this can be used) ....
But also a general question - any way or source to get HP updates/Drivers for the N40L now w/o this service contract ?
I mean I am a private user - I cant/ Wont buy such a care pack , and also upgrading to Server 2012/Essentials etc... from my WHS2011... I mean I cant pay 400€ for the OS to MS as a provate user.... dont know if there is anywhere outside a cheaper offer but tahts what I get here asking - what I can use AFTER WHS2011....
Patschi
Sorry, I don't know a other way to get the latest updates. I still have waranty for my G8, so I didn't care about yet. (I'm also using it just for private purposes). I also read sometimes that people are using normal client systems (e.g. Windows 8) as a server - maybe this would be a possibility for you (If there aren't no more left) or you choose using Windows Server 2012 R2. The cheapest method would be to start using Linux-based systems.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
    • felt
      By felt
    • nlitend1
      By nlitend1
      I upgraded 2 identical systems (both running windows 7) to SSDs and restored images via WHS 2011 and noticed that one of the systems is not running AHCI mode (according to AS SSD benchmark and device manager). I made the 2 registry changes already in windows according to this guide....
      http://www.sevenforums.com/tutorials/61869-ahci-enable-windows-7-vista.html   I then made sure that the BIOS had SATA configured as AHCI (and not IDE). After reboot, I did not get prompted to install the AHCI drivers and the performance is significantly less with the system that appears to be running in IDE mode.   The following are two strange things:  1. Changing the BIOS setting to AHCI or IDE never gives me a BSOD. 2. Stablebit scanner states that both TRIM and NCQ are both working on the SSD and from what I can tell NCQ cannot run without AHCI mode.   This system apparently appears to be "stuck"... in what appears to be IDE mode...Any ideas on what to try at this point? Am i looking at a clean install or even worse... corrupted BIOS?    Thanks!   nlitend1
