diehard
hi guys! i was reading about a RED light flashing on the HP logo on bootup earlier in this thread and that it was a possible indicator of some serious problems
...well, I've got my n54l with the bios mod with Server 2012 essentials all up and running...I've got 16gb Crucial non-ECC Ram
running with it as well...I'm able to boot up and everything seems to be running well enough...was able to restore my drivepool from WHS 2011 no problem
...but this RED flash is freaking me out....do you think it could be the RAM causing issues? or something more serious
with the bios mod not working well or the power supply of the microserver?? any ideas would be much appreciated! Thanks!
hmm...it went blue now...without swapping it out...do you think it was happening because I had the USB boot priority in the settings and it wasnt finding any since I had already installed the OS? just had keyboard and mouse plugged in...now i set the 250gb  hard drive as primary boot source...is there a memtest app which would let me test the RAM within 2012 Essentials?
there's no sign of the red light even when booting from being shut down.
Edited by techmuso
Well, good news, sort of. Would be nice to know what the cause was.
As for RAM testing, I would recommend downloading MemTest86 and booting up with it, rather than trying to test RAM from within WSE2012.
i flashed my n40l with the latest diehard bios and everything works fine.
But now my system says: 10240MB RAM? What happend?
With the stock bios i had 16GB RAM:
Iam using: 16GB Kingston ValueRAM DDR3-1333 ECC DIMM CL9 Dual Kit
Can anybody help?
i only changed one module and leave the  original 2Gbyte Module in.
shame on me  :ph34r: delete my threads... :rolleyes: :rolleyes: :rolleyes: :rolleyes:
Glad you found the "problem" -- let us know how the 16G performs and when you get a chance introduce yourself http://homeservershow.com/forums/index.php?/topic/344-welcome-to-homeservershowcom-forums-introduce-yourself-here/page-11#entry58335
and let us know about your build.
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
