diehard
Thank you for your answers!
@Joe_Miner: I want to use the modified BIOS in order to be able to use SATA port which originally was used by the ODD for my SSD drive. I also need to use the E-SATA port on the back for my ODD. Thank you for clarifying that the modified BIOS won't support the SATA controller mode to be set to RAID.
@ikon: Good information that AHCI is formatting the drives in a certain way, which makes the system unbootable if I switch to RAID.
@jmwills: I have no intentions to run the OS on RAID. I have installed the OS on my SSD disk, but I do want to run RAID on my four drives located in the 4-bay drive beneath the SSD and ODD.
I guess this means that I have to stick to software RAID in the OS, if I want to run OS on my SSD, run the ODD in the E-SATA/SATA port on the back and use RAID on my four drives in the 4-bay drive.
/Micco
Hi guys,
I've been trying to flash the bios on my N40L and follwed all the instructions above but after booting with the USB with modded bios on in the USB slot I get a o4107... rom does not exist message. Any ideas?
Hi guys,
My guess is: Apparently, when Flash.Bat executes it’s not finding the BIOS file o41072911.rom that you were to copy from BIOS-MODS onto the USB Key replacing HP’s stock BIOS file O41072911.rom => Note that both files begin with the letter o (oh) or O (capital oh) and NOT the number 0 (zero).
Check out the latest version of the instructions at HP ProLiant N40L MicroServer Build and BIOS Modification Revisited for more detail.
After much looking I decide to get a N40L with 4GB memory and no HDD
It arrived but along with the 4Gb it had a DVD writer installed,
I replaced this with an Icybox IB-2226StS 2x 2.5-inch SATA Mobile Rack in a 3.5 inch Hard Drive to 5.25 inch Front Bay Bracket Adapter I had lying about, and installes a PEXSATA22I PCIe 2 port sata card.
I also have a Startech eSATA USB DUAL SATA HARD DRIVE ENCLOSURE S252U2ERR, with 2 x 2.5 drives and this is hooked up to the eSATA port to give me working multiport access.
A Samsung MMCRE28G8MXP-0VB 128 Gb SSD & 2 x 2Tb WD greens (from an old NAS unit) complete the build.
Before installing any drives I flashed the BIOS using DieHard's Link. After successfully flashing the BIOS and changing the settings and loading Win7 on the Samsung
Plugging in the S252U2ERR to the eSata port and both drives showed up proving that the port multiplier is working. All drives show as "Hot Swap" including the Samsung.
One of the 2Tb Greens failed and was RMA'd, WD sent back a new 3Tb one, Everything is up and running and I can drop my 2.5" drives into the cradles and copy the data from them on to the 2 x 3.5 " drives. Will post transfer rates in my next post
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
