drapsag Posted March 29, 2012 Share Posted March 29, 2012 Use this link to create the bootable thumb drive http://cvscorp.homes...ey%20Media).exe but replace and rename the BIOS bin file with the one from BIOS-MODS. You should only have to reboot the server with the thumb drive and it will do all the work. Look under the tab for Southbrige stuff there is a lot of stuff there. That's where I found stuff for the ESATA port to recognise my DROBO. Hi the link isn't valid anymore, where can I find this executable? Link to comment Share on other sites More sharing options...
cskenney Posted March 31, 2012 Share Posted March 31, 2012 Hi the link isn't valid anymore, where can I find this executable? That link still works for me. Link to comment Share on other sites More sharing options...
diehard Posted March 31, 2012 Author Share Posted March 31, 2012 I find the cvscorp site goes up and down. I copied all their files to my PC for future use. Link to comment Share on other sites More sharing options...
ikon Posted April 1, 2012 Share Posted April 1, 2012 I find the cvscorp site goes up and down. I copied all their files to my PC for future use. Smart man. Better to have them available locally anyway IMHO. Link to comment Share on other sites More sharing options...
mattd390 Posted April 3, 2012 Share Posted April 3, 2012 The darn link is down again... DOH! Link to comment Share on other sites More sharing options...
heathj Posted April 4, 2012 Share Posted April 4, 2012 Hi, Can I ask the forum for some guidance please? I have carried out the bios mod to my N40L as I am about to install an SSD for the OS. With ports 4 and 5 now running at 3 Gbps, am I going to cause any performance issues if I install a bluray drive (rated at 1.5Gbps) onto port 5? Many thanks Link to comment Share on other sites More sharing options...
yodafett Posted April 4, 2012 Share Posted April 4, 2012 No, Sata spec auto negoiates down per device Link to comment Share on other sites More sharing options...
heathj Posted April 4, 2012 Share Posted April 4, 2012 Many thanks, Link to comment Share on other sites More sharing options...
o2bob Posted April 8, 2012 Share Posted April 8, 2012 Great site.....but have spent most of the evening trying to figure out the bios update. Looks like the link is down http://cvscorp.homes...ey%20Media).exe any suggestions?? Thanks -R Link to comment Share on other sites More sharing options...
diehard Posted April 8, 2012 Author Share Posted April 8, 2012 I just tried it and it's working. Link to comment Share on other sites More sharing options...
