diehard
What if HP relase a new BIOS version tomorrow which fixes a bug or gives us more features on the N40L, would it be possible to flash the BIOS with this newer version? Or does the modified BIOS version in somehow prevent us from doing this?
If you flashed the BIOS with a newer HP version, you would have to go back and put the Mod BIOS back on, if that is what you want.
You can flash the BIOS at any time. Not all features may be available in the new OS if any new features require a new OS install but that should be rare.
Success! I have unlocked the hidden features in the BIOS by using diehard's modified BIOS version! :) Thank you!
I'm currently using a 120 GB Samsung SSD 840 Series (Model number: MZ-7TD120) on the optical drive sata port and have connected the optical drive to the E-SATA port, which now have changed to a ordinary SATA port thanks to the BIOS modification.
I'm installing Windows Server 2012 on my N40L now, hoping everything wil go smoothly in the installation.
/Micco
Is it possible to run the following while running with hardware RAID?
  • 1 x SSD (on the SATA port which the ODD earlier used)
  • 1 x ODD (before the BIOS modification this port is was a E-SATA port, now it's configured to be a SATA port)
  • 4 x HDD (on the 4-slot bay for HDD's)
I tried to change the "SATA Controller mode" in BIOS from ACHI to RAID in order to be able to configure hardware raid. But when Windows Server 2012 tries to start it got an error and reboots.
When I change back to ACHI mode for the "SATA Controller mode" parameter in BIOS, I successfully boot Windows Server 2012 without any errors.
I don't want to use software RAID since it required CPU power, something which the N40L server doesn't have plenty of...
If you changed the Mode to RAID I would suspect that at the least you would have to install the RAID drivers and should probably reinstall your OS but Jump over to Sucessfully Enabled Port Multiplier on eSATA and Read Thread messages #1, 14, 28, 60 for a good flavor of what's going onover there. It's not good news for your case, In particular in #14 Alex says:
I forgot to mention one other important thing that I found:
  • The unlocked BIOS cannot boot if your SATA controller is in RAID mode. This is not an issue if you're running in AHCI mode, and it's not an issue with the official BIOS.
  • I've noticed that the RAID BIOS drive enumeration process never shows up during the boot cycle. This is something to be aware of.
I believe this means that if your server is set to RAID mode, you will not be able to boot your system if you flash the unlocked BIOS. I didn't spend any time diagnosing this problem because my goal was to get port multiplication working.
This is not destructive, because you can simply just flash the official BIOS back.
As is indicated in the posts Joe_Miner referenced, you cannot simply switch the BIOS from AHCI to RAID, or vice-versa, as you like. If you install an OS with the BIOS in AHCI, it will format the drives in a way that will make the system unbootable if you switch to RAID. There is a registry hack that can get around this, but the point is simply that you really should choose which one you want before you install the OS.
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
