diehard
Actually nope, this totally worked - the NEC USB 3 controller is listed for example, onboard audio - all kinds of things which don't exist inside the little box. Now to figure out what to enable to get full speed SATA ports and port multiplier working.
Just to be 100% clear: are you saying the BIOS Mod that people have been using on the N40L does work on the N54L?
Absoloutely, I'm using it right now - 7 disks in mine (Plextor 128gb SSD, 2TB WD Green and 5x 3TB WD Greens)
The thread that just keeps on giving.
I have been trying to determine if I should divide it up into a few separate topics. Thoughts?
I'd take Joe_Miner's "master post" and use it for the basis of a new and possbily locked thread. This post is so deep now that maybe a new sub-topic for the N40L would be appropriate. One to deal with the BIOS and one with RAM Expansion.
The thread does get a LOT of traffic -- we wouldn't want to mess that up but we could probably avoid many of the same questions we get over and over that have been answered here and in other thread(s).
But, Would that break links to discussions within the thread?
May need to discuss in a hangout sometime?
Like I said, it needs it own category with subthreads for RAM, Port Multipler, HDD options, etc.
Just my .02
Just my .02
I agree. However this is not just cutting the thread up. It would require a lot of editing and post moves. A LOT of WORK!
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
