diehard
Thanks Guys for the response but I'm still stuck.
A few points...
Setting to USB boot in BIOS is pointless when you are going to flash the BIOS with a new ROM...the new ROM on boot up will use its default settings on boot up anyway. It seems that USB is default in any case.
Following on from your suggestions I've now tried a few USB keys from various manufacturers but its still the same. Looking on one of the links they suggest using a max 2Gb USB key too so I tried that as well. I've also tried removing all discs and then switching on but still the same red light from switch on.Ive also tried my factory BIOS reset USB key that was made beforehand....and I also made another one fresh on another USB key....but still no joy.
Seemed a bit strange none of this was working so I grabbed a USB key which lights when up active and plugged that in but it didn't light up. I then tried an HP optical USB mouse in one of the other USB sockets and that doesn't light up when they normally they light up red....so its a possible power to USB socket fault and that is maybe the reason why the USB key to do BIOS Flash wont work.
I've had the Motherboard out , re seated the RAM and made sure cables are all plugged in.
Ascskenny says The red light looks like a critical error fault but its only come as a result of doing this BIOS mod (whether its completed on not completed I dont know) . The server and the BIOS was fine before that.
Joe...you've very kindly cleared up what actually happens during the BIOS flash after a start up and I found that extremely helpful..unfortunately I saw none of that as the display suddenly went blank about 20 seconds after switch on, the server then rebooted itself and on restart came up with the red light. The mains was constant throughout and there was no power blip at all. Now If I try to reflash it fails.
So at the moment I am still stuck on POST (therefore I cant get into BIOS at all ) with no svga /vga output to display and what looks like no power or usable USB sockets.
-snip-
In the timeline I saw – the 20 seconds mark was about when my stock 2GB memory was detected – the first 37 seconds after energizing it appears the MicroServer spent the time checking/initializing itself and it wasn’t until the 37-9 seconds mark that the DOS Command Shell executed and began loading the ROM Image – i.e. when it actually began flashing your BIOS.
This timeline was on my Stock MicroServer with only the Stock 2GB RAM module, no drives of any type attached to any SATA ports (I pulled the Stock 250GB HDD and my machine came with no ODD) and no PCIe Cards were installed. Only the Monitor, Keyboard, Mouse, and USB stick (with the BIOS-MOD) were attached (the NIC was not connected). If you had anything else in your Machine I would expect the timeline to be extended out.
So if your system failed at about 20 seconds I would speculate that it failed while checking out & initializing devices on your System Board and then those devices attached to your System Board.
That would appear to narrow the problem down to your System Board while it was initializing and had nothing to do with your attempt to flash the BIOS. The screen flash and self-reboot you saw at 20 seconds adds weight to my suspicions about the System Board & possibly RAM.
If you had upgraded the RAM earlier – then the only remaining test that I can think of (since you’ve re-seated your RAM and other board connections earlier) is to consider removing the upgrade RAM & re-installing the Stock 2GB RAM stick and pull all drives attached to your SATA Ports and any PCIe Cards and try a System Start in that minimal configuration.
If that doesn’t get you past POST then follow CSKenney’s 2nd option -- to Call HP and RMA your System Board.
It’s possible HP may also have ideas on other things to check out. Good Luck & Let us know what you learn from HP.
Pages 82-83 of the HP ProLiant MicroServer Maintenance and Service Guide has a few things to look at regarding failures during POST.
Edited by Joe_Miner
I thought (was hoping) the N40L and N36L BIOS was actually the same, is this not the case? (Based on the topic of this thread)
I should own an N54L within about a week or two, so I was kind of hoping to BIOS mod that.
UPDATE:
My N54L has arrived and has shipped with BIOS 041 "07/29/2011" I can take a photo of the board shortly if anyone is interested also?
If you want to try a modified BIOS for your HO Microserver N40L, take a look at this post.
http://www.bios-mods...er-AMI-BIOS-MOD
leave your comments here.
http://www.bios-mods...nt.php?aid=3276
UPDATE :
Here's a link to my SkyDrive folder and the HP Flash Drive software you need to modify with the bios-mods rom. ( The Link at cvscorp seems to go down quite often)
https://skydrive.liv...368D1A96947!169
Here is the completed flash drive content including the modded BIOS https://skydrive.liv...368D1A96947!169
UPDATE (1 Dec 2012) : If you are looking for the step by step instructions for updating your BIOS then jump to this post. http://homeserversho..._100#entry45899
Does anyone know where the files from the OP link has actually gone?
UPDATE:
Bump
I also received my N54L and am very eager for the BIOS update.
Bump
Don't quote me on this but I think the old update worked,.................. How do I tell in the menus? Anyone know?
Actually nope, this totally worked - the NEC USB 3 controller is listed for example, onboard audio - all kinds of things which don't exist inside the little box. Now to figure out what to enable to get full speed SATA ports and port multiplier working.
Congratulations WizzBang!
The links with the details you're looking for are here and in here.
Hello
Sorry I have not read this entire post.
However I have followed the instructions to install the mod BIOS. So I can move the OS hard drive up in to the optical drive bay on port 5.
I am also wondering if the mod BIOS makes it possible to enable S3 Sleep mode? I have currently got the Microserver N40L to hibernate but it would resume faster from S3 Sleep
Hello
No S3 sleep on the Microserver. For further details....read this entire topic.
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
