diehard
When you say 'nothing', do you mean a completely black screen; no text of any kind at all?
As a follow-up on ikon's question -- If you completely shut the MicroServer down (power down) then restart it and hit F10 during start-up does it take you into BIOS screen?
Is this the infamous 'hit Fxx once a second until something happens' routine?
No. Based on experiences I've had with the MicroServer -- if the flash completed sucessfully then it's my guess the MicroServer "forgot" the SSD in the boot order and put it behind USB ports and Lan and it's just timing out -- If you can get into the BIOS then you can check that hypothesis.
That sounds reasonable. What procedure do you use when doing the F10 thing? My experience is you have to keep hitting an F key about once a second to make sure it registers; for example, hitting F8 to bring up the Boot Menu on many systems.
Agreed. A check of the boot order is in order. I too have fallen prey to that error in the past, not on the N40L, but other systems.
I think we all have at one time or another. Problem is, it's usually infrequent enough that it takes a hour every time before you remember it again :o
@jmwills -- you may have remember from the meet-up -- even switching SSD's required a trip to the BIOS to fix the boot order -- so in between the demo's with the different setups on the MicroServer we had to make a trip to the BIOS -- no big deal if you know you have to do it.
I tried using the hot swap feature that I enabled in the modded BIOS and now the eject media icon shows up in the task bars menu. But when I do try to eject my drive it a popup appears saying:
"This device is currently in use. Close any windows or programs that might be using the device, and then try again."
You may not want to hear this, but I've found, when this happens, that I can get the drive safely removed by going into Disk Manager and putting the drive offline. It's a bit of a PITA to have to do this, but it does seem to work.
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
