diehard
Dear Friends,
As I promised I report back now on the 2x8GB Kingston KVR16E11/8I modules.
The module specification is DDR3-1600 11-11-11-13 but during the tests I was not able to change any operating parameters in BIOS. It seems to me that the northbridge (NB which is integrated in the CPU) has hardcoded parameters for DDR3-800 6-6-6-15 settings.
JEDEC
Standard Name_Memory clock_I/O bus clock_Data rate_Peak transfer_ Timings_ CAS latency
(MHz) (MHz) (MT/s) (MB/s) (CL-tRCD-tRP) (ns)
DDR3-800 100 400 800 6400 6-6-6 15  
It means that we cannot achieve higher memory bandwidth with faster memory sticks. My MemTest 4.0b tests showed me however that the original 2GB HP stick alone pushed about 3000 MB/s data till the Kingston modules performed about 3600 MB/s. MemTest switching off ECC correction to test the real memory reliability and making this with 64bit addressing. In 32bit Windows XP environment this 20% advantage is melting to 5-10%. I assume it is because of the time spent on ECC calculating and the 3GB addressing limit. For the 5-10% lead of the Kingston modules can be the memory bank interleaving – dual channel configuration accounted for.
As conclusion I would say that the 2x8GB Kingston KVR16E11/8I modules are working well in HP N40L, but there is no advantage other than having a lot of RAM to count on. I am sure that the DD3-1600 sticks would never be to hot working on the DDR3-800 specifications.
It was very disappointing that my seven years old simple DDR Pentium 4 configuration is performing on pair regarding memory throughput. Yesterday I put an AMD A10 configuration for the boys to game together. IT performed around 14500 MB/s in the MemTest.
So grab these modules if you want a low computing performance, huge RAM storage capacity NAS at home. :)
Edited by karmantyu
Thanks for the report karmantyu. For what it's worth, I believe most people are mainly interested in just getting 16GB of RAM working reliably; that has been the biggest struggle. Almost everyone can get 8GB working fine, but 16GB has been a struggle.
It looks like you have found & tested some RAM, namely the Kingston, that is a good fit. Have you had any instances where the system would only report 8GB of total RAM when you had 16GB installed?
I have no OS installed yet. The system (BIOS) and the POST screen always reporting 16GB. There were not a single instance reporting 8GB. Do you have the 8GB problem when OS booting or soon on the BIOS POST page?
Some folks were seeing 16 in the BIOS but only 8 in the OS
check the entire thread and I think the posts are in here (yea, I know it 10 pages long)
Does anyone know of or have an "idiot's Guide" to flashing the BIOS on the MicroServer. [bTW -- I'm the idiot I'm thinking about :) ]
It would be nice if the first post by the OP had detailed instructions for flashing the BIOS for us dummies. Rather than having you search a bunch of other threads elsewhere to "find" the instructions, seeing as this is a Sticky.
I also believe Joe_Miner gets 8GB sometimes in the POST. He reboots and it usually comes back with 16.
I remember the old times when I read about such problems. I still have a functioning Abit BX6 2 motherboard with Intel 440BX chipset. It has 4 memory slots and it was trivial that you can put in 4x256 MB sticks. It booted sometimes with 1GB RAM recognized and sometimes with 768 MB but the OS was never stable until I removed one stick and left so with 768 MB. The problem was something about memory density and chipcount and memory bank handling. Intel never stated that BX can handle 1 GB RAM. So I would say when BIOS detecting different RAM numbers then there is something wrong, incompatible. The first problem will arise when the OS is trying to access the compromised RAM space.
I will test N40L with a 64bit OS on the weekend and will report back if there is some incompatibility issue.
I added a link to the first post that will jump to the post by Joe_Miner explaining the step by step instructions.
Thanks. That helped. One thing with that process is that the HP web interface to setup the flash drive made the drive freeze and loaded a ton of other files to the drive off my C: drive, even deleting part of the name of the drive. So I had to go to the folder directly and run the HPQUSB.exe. But even that did not finish up cleanly, ending with a pop-up that said "program did not install correctly". Using Windows 7 Ulitimate. But I just closed that pop-up window and checked the drive and I do now have the thumb drive with all the files as Joe posted were needed. Just hope they are all good files.
Edited by g725s
The issues you have run into is one of the reasons for reading through this entire topic (all 10 pages) instead of just jumping to the How-to. Others have had some difficulty and it turned out to be an issue with their USB stick (perhaps the brand they used).
I am not saying that you will have problems now with the information you have posted or that we won't help if you have trouble. I am simply pointing out that there still may be some value to read through all the posts.
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
