diehard
I use that link:
http://h18004.www1.h...hp_memtool.html
...to check memory compatiility, and thats what i got:
Do you think there is no chance to run my 4GB sticks ? Never update BIOS - which BIOS will be the best ?
16Gb 2x8 Kingston KVR16E11/8I module works well with factory BIOS 07/29/2011!
http://www.kingston.com/dataSheets/KVR16E11_8I.pdf
I use that link:
http://www.kingston....KVR16E11_8I.pdf
Hi Karmantyu! Glad you found some sticks that worked & thanks for the link. Were you able to use the other sticks in another build or did you send em back to HP?
Have you added anything else to your MicroServer? Which OS are you running?
Hi Joe,
Sincerely I don’t know what to do with the 2Gb stick delivered with the microserver. You can have it if you want it. (PM your address)
Anybody who is considering to get the KVR16E11/8I sticks I advise just wait a few days. I did not encountered any problem -some people reporting only part success with other type of 2x8Gb sticks e.g. the server booting once with 8Gb and other time with 16Gb recognized – but the server booting always with 16Gb recognized. Yesterday I run Memtest 4.0b on a six our torture and no problem at all. Memspeed was around 3850Mb/s. I am looking for some utility to check if the ECC correction is active and functioning from the CPU/motherboard side and I will report back when everything is 100% OK.
The N40L is still on the original 07/29/2011 factory BIOS and I am looking for a modified one. It is not easy to decide which one is the latest and most stable version.
  • On this forum we have diehard’s mode from 01/03/2012.
  • On overclockers.com.au we have mods from 09/06/2012 – it is for N36L but stated well working on N40L. http://forums.overcl...81&postcount=77
  • We have TheBay’s ROM from 9/29/2011
http://www.avforums....os-support.html
  • We have cmiloml’s BIOS form 10/19/2011
http://www.bios-mods...er-AMI-BIOS-MOD
Sincerely, I don’t know which one to choose. Well it would be nice to put a Microserver BIOS mod WIKI together.
Do you have any suggestion?
I have only the server stuffed with 16Gb ECC + 6x2Tb WD Green for data array + USB sticks for OS. I am still testing as you see. Planning to install FreeBSD 9 with ZFSguru’s interface and have a secure RAIDZ2 storage array. Any recommendations are welcome guys!
Edited by karmantyu
The version you are referring to as Diehards is the one from the Bios-mods forum. I think the majority of people in this forum that are using a modified Bios are using the version from Bios-mods (I know I am).
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
