diehard
Tried with one stick only. The same result. HP LED logo is red for one sec and nothing happened after. Fan is working, screen is black. My BIOS is 041 dated to 07/29/2011
If these are parts that HP says are compatible, I would call HP Tech Support.
Your BIOS is the current factory BIOS – that’s not your issue.
I agree with ikon – you need to contact HP Tech Support.
Have you tried the other 11 sticks in your picture? (i.e. one at a time)
Even if you find 4GB Stick(s) that are good you will still want to contact HP to RMA the failed sticks.
I’m using Kingston 8GB (2 x 4GB) 240-Pin DDR3 SDRAM ECC Unbuffered DDR3 1333 (PC3 10600) Server Memory Model KVR1333D3E9SK2/8G in my first MicroServer without issue from the first power-up.
See the threads below for more info:
RAM for HP Proliant Microserver
More Interesting MicroServer Links
You can Check out other RAM Compatibility at the HP MicroServer N40L Wiki
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
