  • Replies 557
    119
  • Joe_Miner
    62
  • jmwills
    46
  • cskenney
    24
Popular Posts
Hi Anttech,   I had the same issue and couldn't download it from the german site.   I found a mirror at the following address :   http://translate.google.com/translate?sl=auto&tl=en&js=n
Well I upped it to my dropbox. Please serve yourselves.   https://www.dropbox.com/s/qff7abgmt7hau6z/O41100113.ZIP Well I upped it to my dropbox. Please serve yourselves.   https://www.dropbox.co
Here are the two original versions that I have now posted in dropbox   http://www.dropbox.com/s/u6r1ogp2gt7ju1c/SP64420.exe?dl=0 http://www.dropbox.com/s/m1sisxxaa0oszoc/SP54344.exe?dl=0
Posted Images
I would do what jmwills says, but it's also possible that the RAM is right on the edge of stability. IOW, it may be pushing the limits of what the system can take. If multiple types of RAM exhibit this kind of behaviour, and it was my system, I would never use 16GB in a production system.
I would also run MemTest86 for an extended period (24 - 48 hrs.) to see if the RAM exhibits periodic errors.
  • 1 month later...
Hi. I have strange issue. My NL40 worked fine with 2x2GB ECC sticks which where genuine RAM sticks installed in NL40. I purchased some 4GB ECC RAM sticks and after i install two in the server I have no BIOS post only black screen. Here photos of the sticks:
Some idea what can be the problem ? After i press the power button i see red HP logo for a second. Fan is working.
Perhaps you should post a photo of the 2GB sticks.
Here one of the 2GB sticks which works fine:
Edited by Komornick
Joe_Miner
-snip-
None of the 12 HP 4GB RAM sticks work in your N40L? Have you tried them individually -- i.e. load 1 HP 4GB RAM stick and power on -- to see if any work? Have you replaced you earlier 2*2GB RAM sticks to see if it still powers on?
Have you checked if the new RAM is on the list of those that people have tested as working?
Didnt check.
I installed two pairs of 4GB. didnt check mem indyvidually. I installed 2x2GB after and they work fine.
Joe_Miner
Didnt check.
Assuming these sticks are on HP's list as compatible with the N40L -- I suspect when you call HP about the their RAM they will want to know if you tested each individually.
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
