hp bios are trash
Again, sorry I'm new here... How do I locate these post?
Also thanks a bunch for the prompt advice
  • Replies 557
    119
  • Joe_Miner
    62
  • jmwills
    46
  • cskenney
    24
Popular Posts
Hi Anttech,   I had the same issue and couldn't download it from the german site.   I found a mirror at the following address :   http://translate.google.com/translate?sl=auto&tl=en&js=n
Well I upped it to my dropbox. Please serve yourselves.   https://www.dropbox.com/s/qff7abgmt7hau6z/O41100113.ZIP Well I upped it to my dropbox. Please serve yourselves.   https://www.dropbox.co
Here are the two original versions that I have now posted in dropbox   http://www.dropbox.com/s/u6r1ogp2gt7ju1c/SP64420.exe?dl=0 http://www.dropbox.com/s/m1sisxxaa0oszoc/SP54344.exe?dl=0
Posted Images
cskenney
This topic is specifically about the Bios for the HP Microserver. What you are asking about is the Bios on another machine.
I would recommend you investigate the web site Bios Mods. That is the site that has the modified Bios that everyone here is using for their microserver.
You can also follow @TheWizBM on Twitter and send him your questions. He is also associated withe the Bios Mods site.
Hi everyone,
My name is Michael and i need your help.
I though i had read everything i need to flash my bios on my Hp n40l
Unfortunantly it stuffed up!!!
it is now bricked and dont know what to do.
it will power up with a short red light and then nothing. No screen
Can i do anything to get it fixed??
your help will be greatly appreciated
FockGhost
hello all, just a question in regards to bios flashing.
I followed diehards post in regards to flashing the bios. and i kept getting "RomPaq may take a few minutes to get started, please be patient... Command or filename not recognized".
thought it may have something to do with
but replace and rename the BIOS bin file with the one from BIOS-MODS.
what am i doing wrong?
The instructions here are confusing (I don't see a Bios.bin etc) but I figured it out using my own trial and error method. Here's what I did.
1) Run HPQUSB.exe in windows to create a bootable USB stick
2) Browse the USB drive and delete everything EXCEPT command.com
3) Download flash.zip from:
https://skydrive.liv...68D1A96947!1060
4) Extract flash.zip, and copy all files onto the root of your flash drive
5) Boot from the USB drive on your Microserver
6) Hit enter, enter, enter when it asks for the time date etc.
7) Once you see the command promt, type FLASH
8) Hit Enter, you'll see it write the new Bios VERY quickly and will return to command prompt.
9) That's it! Reboot the server, hit F10 and you'll see all the new wonderful option.
Here are the best set of over all instructions on what the MicroServer is capable of and how to set it up.
http://homeserversho...dification.html
The following accessory made it MUCH easier to install a 2.5" & 3.5" hard drive into the ODD bay though.
CY DOCK MB971SP-B 1Bay DuoSwap 5.25inch Hot Swap 2.5/3.5inch SATA DOCK Storage
http://www.amazon.co...ils_o06_s00_i00
Edited by JazJon
  • 4 weeks later...
Getting ready to move my N40L over to Server 2012 Essentials, and just wondered whether this BIOS mod is still relevant or has it been superseded by a later HP or modded BIOS?
Has anyone found a setting in the modded BIOS to get the eSATA port multiplier to see more than one drive in an external multi-drive eSATA box?
Tom
Tom
Not possible just buy a card. Search amazon for SiL3132
Edited by JazJon
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • AnthonyB
      By AnthonyB
      Fixes Upgrade Requirement:
      Important Notes:
      Firmware Dependencies:
      None
      Problems Fixed:
      Known Issues:
      None
    • DaMenace
      By DaMenace
    • bennybennybenny
      By bennybennybenny
      Hey guys,
      Cheers Benny
