g725s 18 Posted December 22, 2011 Share Posted December 22, 2011 (edited) Just installed WHS 2011. And I have only one Alert saying "Backup is not configured for the server". My HP MicroServer has only two drives currently, a 250gb drive(C:/D:) that has the OS, and a 1.5tb drive(E:) where I'd like to have my Backups saved. When I installed the OS on the 250gb drive, by default it setup the Client Computer Backups folder on the D: drive. So I tried moving the Client Computer Backups folder to the E: drive which is the 1.5tb drive. But when I go to "Set up Backup for the server" it say; "The wizard cannot find any disks that are suitable for a backup destination. Attach a backup disk to the server. And then click Refresh list." Refresh list does nothing of course. But it will find the destination if that folder in on the D: drive. Edited December 22, 2011 by g725s Link to post Share on other sites
gcoupe 5 Posted December 22, 2011 Share Posted December 22, 2011 (edited) I think you're getting confused by the fact that WHS 2011 has two types of backups: - backups of client PCs, which are held in the Client Computer Backups folder, and - backups of the server itself, which are held on dedicated drives (i.e. they cannot be held on drives that hold Shared Folders) So if you've moved the Client Computer Backups folder over to the E: drive, you're using it as a storage drive for Shared Folders, and therefore it cannot be used as a dedicated drive for Server Backups. If you want to use the E: drive for Shared Folders AND have Server Backups configured, then you are going to have to add another drive, either internally, or using an external USB drive... Alternatively, I'm pretty sure you could use the Disk Management utility in the Server Manager to split the 1.5TB drive into two partitions (E: and F:) and then use one for Shared Folders and the other for Server Backups. My personal preference, though, would be to have a separate physical drive dedicated to server backups. Edited December 22, 2011 by gcoupe Link to post Share on other sites
jmwills 284 Posted December 22, 2011 Share Posted December 22, 2011 WHS Server Backup requires a dedicated drive so you will need a third drive. Link to post Share on other sites
gcoupe 5 Posted December 22, 2011 Share Posted December 22, 2011 WHS Server Backup requires a dedicated drive so you will need a third drive. Ah - OK, I wasn't entirely sure about it - thanks for the clarification... Link to post Share on other sites
jmwills 284 Posted December 22, 2011 Share Posted December 22, 2011 You can use a drive that is passed thru from a host in virtualization but WHS backup for the server wants a drive for itself. A third party solution could use the same drive for clients and the server. Crazy...... Link to post Share on other sites
g725s 18 Posted December 23, 2011 Author Share Posted December 23, 2011 Thanks for all the responses. So I get that you are saying that you cannot put the WHS backup on a partitioned drive? How much space does a WHS backup need? Link to post Share on other sites
jmwills 284 Posted December 23, 2011 Share Posted December 23, 2011 You are correct. Depends on how big the items you configured for backup are. Link to post Share on other sites
