Client Recovery Saga - Success but not without issues
MediaDaveP
I had the misfortune of losing the SSD that hosted my Win7 Ultimate OS on my main desktop PC this week. It was time for a system restore via WHS2011. This event was not a controlled event and not documented for a blog post as I went. All steps may not be included but it still makes for an instructive tale.
First a little background. The desktop machine is an ASUS M4A89GTD-PRO, AMD Phenom II x4, 8Gb Ram, 60Gb SSD for C: drive, Two stripped(dynamic) WD 500GB Green Drives for D:, E: & F: are 2Gb WD Green drives used for mirroring music, videos, & Recorded TV from on machines. Yes, the 60 GB drive was too small and many apps where installed to D:
The SSD failure was sudden. The machine would just not boot after I had the machine off for 2-days during an office remodel. Inspecting the BIOS showed that the drive was not detected. An alternate spare boot drive on the same cables & SATA port worked just fine. Drive would not work in a test machine either.
This being my second OCZ drive to fail after only 6 months, I went out and bought an Intel 320 series (SATA II) 120GB drive and installed it. It was detected right away by the BIOS.
My system recovery devices are USB memory sticks labeled for each client. I popped this into the desktop and configured the BIOS boot settings to boot from the removable device. BIOS save & reboot and I off to the races. First lesson learned was that you have to all your drivers on the USB stick as well. That was a simple to fix. I opened the WHS Dashboard on another working machine, opened the backup for the desktop and copied the Drivers for Full System Restore folder to the USB Recovery stick. Now I could start the recovery process after a reboot & driver load.
I had some doubt about the recovery since I was starting with a new bare drive. Would the recovery make the drive bootable? In my case, no, 45 minutes later I had a drive that I could not boot but had all my files. Windows Repair from the Windows media could not repair the drive so that it was bootable.
Ok, I started again with the Windows media disk and reinstalled windows on the C: drive and ensured everything is partitioned correctly.
It was now time to repeat the recovery process. Another 45 minutes later and I still could not boot the drive. Things were beginning to look grim.
Then I remembered the Windows Repair trick. Two passes through the Repair process and I had a working system again.
This is not something the average consumer is going to do. Guess this is why WHS is relegated to the enthusiasts. In the end it saved my data, applications, and settings just like it should have. The process is not something my none techy friends are going to survive with their sanity.
@MediaDaveP
Great post and unfortunate to hear about the boot process not restoring correctly. I need to find some time to test this on one of my systems. Did it have to do with the small partition that Win 7 creates? Was that backed up and restored correctly?
45 minutes doesn't seem bad for the entire restore. I thought it would be much slower.
Anybody else experience this?
I'm wondering if the 2 SSD's died because you have a paging file on the SSD or one of the other items that are recommended to change when you implement an SSD. Did you install win7 from scratch to the SSD for your original install?
ikon,
I installed Win7 from scratch when I built the systems using SSDs. I thought Windows took care of all SSD implementation details. Can you point at the list of recommended changes?
I backed the entire c: drive up and the backup was complete. The restore also completed with no reported errors.
Are you talking the boot manager when you say "small partition that Win 7 creates"?
Recovery was pretty quick due to the small drive size I suspect.
ikon,
This is even more interesting then. Win7 is indeed supposed to take care of the SSD settings. I can't point you to a specific list but search these forums; it has been discussed quite a bit.
ikon,
It takes care of basic items but most requires manual changes. See the link below for some stuff I do. Hopefully others will add what they do and it can be a good tool for all.
http://homeservershow.com/forums/index.php?/topic/3333-ssd-setup-practices-by-forum-users/
    • Rodf
      By Rodf
      I'm looking into replacing my desktop's old, failing HD with an SSD. I've got a Dell XPS 8700. I've look up the configuration on Dell's website, entering my machine's service tag (DK49122). I've found the component which is listed as:
      KPF74 : Module,Hard Drive,1T,S3,7.2K,5 12E,#1,G-BP INFO,1ST BOOT,HARD DRIVE HD,1TB,S3,7.2K,512E,SGT-GRDABP
      I know it's a 1 TB drive. It looks to me like it's a SATA III drive. Am I correct?
      Assuming I've correctly identified the drive, then I've found what looks like a good replacement part on Newegg which is listed like this: SAMSUNG 860 EVO Series 2.5" 1TB SATA III V-NAND 3-bit MLC Internal Solid State Drive (SSD) MZ-76E1T0B/AM
      So, have a got a good replacement SSD for my machine's old HD?
    • xelent
      By xelent
      Hi there,
      I've just gotten my old Proliant server out from mothballs recently to use as a Backup controller for my photographic archive. It's specs are a standard G840 2.8GHz Dual core with 16 GB of ram installed with a standard 350 watt PSU. I'm running WSE 2019 with 4x1TB HDD's installed in the 4 bay drive cage. 3 drives are formatted to RAID 0 in WSE (not embedded HP RAID) and one drive acts as the system/boot drive.
      The server is surprisingly responsive given its age, with LAN transfer speeds between 84-94MBs. So has pretty much taken center stage in my backup control between my  external drives and 4x1TB RAID 0 NAS.
      However, I have been wanting to attach a 256GB SSD boot drive for my OS, so that I can utilize the full capacity of my 4 bay drive. It seems that the BIOS will not let you boot any HDD/SSD off the spare SATA connection on my MB. Anyway I am hoping to eventually attach a PCIe USB 3 card to that. But in the meantime I would like to boot a separate drive other than the 4 bay one already installed.
      I gather that you can install a PCIe SSD card on this machine. But it's not clear to me as to what kind of card and drive would be suitable for this server. I realize that my MB is PCIe gen 2, which will incur diminished speed compared to the latest gen 3 MBs. But should I be using NVMe or SATA m.2 drives? Or does it even matter? Also will the BIOS allow me to boot from this drive?
      Thanks for taking the time.
    • Karazzi
      By Karazzi
      Hi everyone.
      New to this forum.
      I have a gen8 microserver running at home, where I have installed an SSD in the ODD sata slot. On the SSD I have installed Ubuntu Server 18.04.
      I have then created a logical volume witht the raid controller and can then boot to the SSD. So far so good.
      My problem emerges when I reboot the system. The logical volume disapears and it gives the error: "boot logical drive is configured but is missing or offline".
      I then have to go into the utility and reconfigure the logical volume. Kind of annoying, when trying to run a headless setup.
    • Laris
      By Laris
      Hi all,
      Now I share my extreamly mod for your reference
    • ICYDOCK_Chris
      By ICYDOCK_Chris
      ICY DOCK is the leading expert in data storage enclosures and accessories.
      Introducing ToughArmor
      ToughArmor is ICY DOCK’s rugged enterprise-grade line of 2.5” SSD and HDD enclosures, utilizing the standard external 5.25” bay, external 3.5” bay (floppy bay), and the slim optical bay (ODD bay). All ToughArmor models feature ruggedized full-metal enclosures and trays, to keep your sensitive data protected, as well as meeting many flammability requirements. It features many high-density storage options, supporting as many as 16x 2.5” drives, or as few as one. Models are available to support SATA, SAS, and now, U.2 NVMe drives, giving you flexibility in choosing drives that work best for you. The strength and build quality of all of our products is backed by a full 3-year warranty against all defects. ToughArmor is used and approved by Tier 1 companies such as Hewlett Packard (HP), General Electric, NASA, as well as the US Armed Forces. For more information on our ToughArmor line, read our ToughArmor documentation here. Links to all of the products discussed here can be found in the documentation. All ToughArmor products can be view here.
      ToughArmor for SATA 3.5” / 5.25” Bays
      For SATA and SAS drives installing into 3.5” and 5.25” bays, we have a large number of options available. In the 3.5” bay, there are models that support one to three drives, some with features such as key-lock trays and hardware RAID capabilities. The larger 5.25” bay supports between four and eight drives in a single bay, and up to 16 when using two bays. These denser options offer cooling fans, to keep the large number of drives cool under heavy load. These models have a wide array of uses. The MB991U3-1SB is our portable ToughArmor unit you can take anywhere, and works over USB. The MB992SKR-B is a 2-bay model with a hardware RAID chip, with modes for RAID 0, RAID 1, BIG, and JBOD.
      There are also our more traditional drive carriers that install into a single 5.25” bay. While these models don’t have USB support or a RAID chip, they still have direct SATA connections, the full-metal enclosure, and the 3-year warranty.  The 4-bay (MB994SP-4S), 6-bay (MB996SP-6SB), and 8-bay (MB998SP-B) models are perfect for any general applications that require hot-swappable SATA hard drives and SSDs in a dense storage enclosure.
      ToughArmor for NVME
      Recently, ICY DOCK has released the first-ever hot-swap cages for U.2 NVMe drives.  U.2 drives use the standard 2.5” size familiar from SATA SSDs, but utilize the NVMe specification allowing for transfer rates of up to 32GB/s. ICY DOCK U.2 NVMe cages come in one and four bay models, and utilize a single Mini-SAS HD connection for each drive. The single-bay model (MB601VK-B) fits in a single 3.5” bay, great for space-limited tasks that require only a single drive.  Small-form-factor systems, DVR systems, and photo/video editing systems can benefit from high-performance storage in a small space. If you need more drives, the 4-bay model (MB699VP-B) is the one for you, and even works great in RAID setups.  These are used in datacenters around the world, that need dense NVMe based storage. Both of these models use a Mini-SAS HD port / cable for each drive, so make sure to prepare your system with enough Mini-SAS HD ports.
      ToughArmor for Optical Drive Bays
      ICY DOCK also has several drive cages that fit into slim (12.7mm) and ultra-slim (9.5mm) optical drive bays. These can serve to replace existing drive readers in laptops and desktop systems, and can also be paired with several of our 5.25” bay brackets. Perfect for space-critical applications that require drives to be installed in the smallest possible space. Common uses are in Small-Form-Factor PCs, media PCs, Home Theater PCs (HTPC), and security footage systems. In industrial uses, these are often found in 1U and 2U rack-mounted systems with limited space availability, and portable workstations/laptops.
      If you have any questions about the models mentioned here, or anything else, send us an email at tech@icydock.com. We offer first-class customer support for all our products, from pre-purchasing info, product selection help, walking you through installation, and issue troubleshooting. In addition to email, we offer phone and live web-chat customer support, which can be found here.  Our knowledgeable support technicians are available Monday-Friday from 10:00am-5:00pm PST.
