Problem booting OS after Highpoint 2680 RAID set up
krom
I'm having a problem booting into my OS since I installed and configured a RAID 5 array with a Highpoint 2680 card. The array creation process went well and the card recognizes the array but right after leaving the 2680 screen during POST all I get is a blinking cursor. If I unhook the drives form the 2680 I can boot just fine. In the system BIOS I have the proper drive designated as the boot drive too. The mobo is a Gigabyte GA-990FXA-UD3. Any thoughts? Thanks.
A couple of updates. I did update the 2680 to the latest firmware v1.1 but that didn't help. Also disabled int13 as @Timekills suggested in this earlier post:
http://homeservershow.com/forums/index.php?/topic/2266-highpoint-rocket-raid-2680-installation-issue/page__st__20
I didn't notice any speed up during boot on the 2680 screen during post. In any case that didn't help.
I do notice that the array is labeled as uninitialized in the 2680 screen during boot/post. Not sure if that makes a difference but I don't see any place to initialize the array.
If by board you mean the mobo vs. the 2680 then it's set to AHCI...but I'm running the RAID from the 2680 not the motherboard. Do I still need to set it to RAID? The drives attached to the SATA ports on the mother board are not in a RAID configuration.
Interesting update, I had a separate spinning disk connected to the mobo sata ports (this was my d: drive). Since nothing else was working I decided to disconnect it (I was clutching at straws at this point). That took care of the problem. I'm not sure why that made a difference but it did.
Not sure if the RAID card was a red herring given what fixed the problem, but another way to speed up your boot time and prevent the RAID card from being checked for boot is to enable the Intel RAID option in BIOS, even if you're not using it as RAID. It will bypass the RAID card check. Of course, that also means you'd have to disable if you needed to get into the RAID setup before the OS booted.
    • Giuseppolino87
      By Giuseppolino87
      Hi everyone, today I wanted to install esxi 6.7 to try out the various functions, my question is the following, I have a server where I have installed esxi in an SSD and I have two other 4 tb disks so 8 tb total.  I would like to make sure that when I create a virtual machine in this case I will install the various virtual machines in the SSD and use the two disks for data.  So how can I do this?  Thank you very much for those who can help me.
    • E3000
      By E3000
      Looking for a quick answer here from someone in the know...
      I upgraded some of the internals of my Gen8 server and at the same time I did a BIOS reset as I had forgotten the password that I had set years ago. When booting back up the upgraded hardware was detected and fine but I received Error 1784 - Drive Array - Logical Drive Failure. I believe this is due to a setting change in the BIOS and not anything hardware related. I have gone into IP/SSA and see the array needs to be rebuilt. I had all drives configured as single RAID0. It says all data will be lost if I reconfigure this but I remember reading somewhere on here that the data will be fine if I reconfigure as RAID0.
      I do have a backup of course, but it’s not a high availability mirror and will take some time to get back the way I had it, so just want to know if it’s safe to reconfigure the RAID0 without erasing the drives. I have tried pulling the drives out and connecting them to another PC and they are fine. Can anyone tell me which options to choose to get these back to normal and remove the flashing red light?
      Thanks 😶
    • Mark Belanger
      By Mark Belanger
      Greetings,
      I'm new to the HPMSG8 world and so far I'm loving it. I have a stock Xeon with 16G of aftermarket memory with iLO patched to 2.70. Next up is adding a RAID card, so I can put my boot SSD on the onboard RAID. I picked up a LSI SAS9211-8i on Amazon, but am struggling to flash it to IT mode on the MicroServer. Is this even possible? Unfortunately, the only other system I have with PCI slots is 32-bit.
      Any pointers would be greatly appreciated.
      -MB
    • TakiBot
      By TakiBot
      I've got my hands on a HP N40L.
      Can i use raid 1+0 on my 4 2TB WD RED or only 1 and 0.
      Thanks for the help.
    • arefiev.dm
      By arefiev.dm
      Hello! I put P222 on my Gen8 server, but I can not use RAID6. Can someone share the key?
