G. WadeTech
New PC Build... Any help is appreciated.
G. WadeTech
I had an issue this morning when I tried to fire up my Virtual Box VM of Windows 8 Dev Preview Edition. The error was that the VM did not have enough memory. The VM is set to use 4GB's and my Win7 Pro system was using 13GB's of RAM and did not free up enough RAM for the VM to use. I know that WIndows 7 will use system RAM as needed and should free up RAM if needed by another application but I fear something is wrong. Any ideas? Have you had this issue? I have started going through my Motherboard manual to look at Bios settings. I enabled XMP this morning and restarted. However, I don't think that will do anything to fix the issue but I turned XMP on to utilize the features that I have.
ikon
Wondering if you just have so many apps open that win7 is having a hard time freeing up enough memory. Have you tried a reboot? Or maybe you could try increasing the cache file size to see if Win7 will use it to free up some RAM.
Mr_Smartepants
If your Win7 host is the x64 variety, then there is a known memory leak bug when certain AV clients are used. I've seen it my self with SAV and others have reported NOD32 has the same bug.
AFAIK it has to do with how the svchost process is multiplied and not released properly.
I just restart my PC every few days.
ikon
Interesting info. Thanks.
G. WadeTech
I believe you are correct. I am using Win7 64-bit Pro version and I have only had the issue twice now but svchost process has been out of control both times. A restart fixes the issue... I wonder when Microsoft is going to patch that up?
ikon
I haven't noticed this issue. I guess it doesn't affect MS Security Essentials?
G. WadeTech
The last two days I have used my system I have not noticed the issue again... I am using MS Security Essentials.
Mr_Smartepants
I think the bug affects all NT6 (Vista/Win7/etc) x64 variants and has to do with svchost RAM usage and incorrect memory release. It's not just AV software that's the culprit but any app that uses the svchost process. AV programs are just notoriously bad at memory management.
ikon
Hmmm, I'm running Win7x64 and I haven't noticed this issue. I hardly every reboot.
ImTheTypeOfGuy
Ditto. I reboot only when required de o updates so about once a month maybe.
    • Dave
    • Dave
      By Dave
      The SDM R4 is SOLD OUT!
      The SDM R4 is a bracket that facilitates mounting two additional 2.5″ drives in a HP MicroServer Gen8. There are also mounting holes for fans across the bottom to help cool RAID/SATA cards. The kit includes all the fasteners needed to install.
      With optional Stackers you can run four 2.5″ drives on the SDM R4. The SDM R4 will support four 9.5MM 2.5″ drives. If you want to run four drives on the SDM R4, you need to order SSB stacking brackets listed below. One set of SSB per drive pair, four drives will require two SSB kits. Because of the size of the SDM R4, if you are going to boot your server using the internal USB port, you will need to use a USB stick that is shorter than 1″. For more information on mounting instructions look here: http://homeservershow.com/forums/index.php?/topic/5960-hp-ms-g8-25-drive-bracket-revision-history-new-rev-35-and-rev-4-info/?p=137922
      The SDM R3.5 is in stock and ready to ship!
      The SDM R3.5 is a bracket that facilitates mounting one additional 2.5″ drive in a HP MicroServer Gen8. The kit includes all the fasteners needed to install.
      With optional Stackers you can run two 2.5″ drives on the SDM R3.5. The SDM R3.5 will support two 9.5MM 2.5″ drives. If you want to run two drives on the SDM R3.5, you need to order SSB stacking brackets listed below. One set of SSB per drive pair. For more information on mounting instructions look here:  http://homeservershow.com/forums/index.php?/topic/5960-hp-ms-g8-25-drive-bracket-revision-history-new-rev-35-and-rev-4-info/?p=137922
      SSB-9.5 for 9.5mm drives $10
      Schoondoggy Stacking Brackets can be used to stack two 2.5” drives. All screws are included
      SSB-7 for 7mm drives $10
      SOC-MSG8-R1 kit for 9.5mm optical drives to latch it in place. Screws included $9.
    • Henrik
      By Henrik
      Hi Community,
      First, my specs (briefly):
      MicroServer Gen10
      AMD Opteron X3216
      Win Server 2016
      Problem:
      The Taskmanager shows only 1 CPU-core instead of 2.
      (ref. image 1)
      Solutions tried:
      checked msconfig...no CPU-Limit set checked, whether other users see the same amount of CPU-cores in task-manager (ref. image-link (internal) 2)
      Anyone out there with an idea to solve this?
      Greets
      Henrik
    • Sug7
      By Sug7
      Hi Guys,
      New member here, some great info on this forum so hopefully a few of you have experience with the Intel E3-1260L CPU running in a HP Microserver Gen8?
      I know for sure it will work as I’ve seen some good threads on here but can anyone tell me if the upgrade made a noticeable difference in the fan speeds and noise?
      Im looking at putting two Gen8’s in a living room in place of an old N54L so cautious of too much noise..
    • Orion
      By Orion
      I am building a Ryzen machine. Using the new Ryzen 7. What is the best ram to use. Obviously ddr4. And recommendations on brand and size
