G. WadeTech
New PC Build... Any help is appreciated.
pcdoc
I don't know how you get done all the stuff you do.
Passion. I love to learn and try new things so it keeps me going.
ImTheTypeOfGuy
My passion is there. The family, not so much. For some reason they like me to be with them.
ikon
Yeah. Families. Go figure :D
G. WadeTech
I totally agree with you ImTheTypeOfGuy.
I have posted pics of my new system (click on the below link). Thanks for all of your help and feedback.
http://www.flickr.com/photos/15216611@N06/sets/72157628288722179/
Things I plan to get in the future for this build:
SSD to utilize the Intel SRT
Quad LCD arm from amazon
Edited by G. WadeTech
ikon
IThings I plan to get in the future for this build:
What is an LCD arm?
BTW, cool slide show. Didn't know you could do that in these forums. Wonder if it works if the album is stored in the forums gallery?
G. WadeTech
What is an LCD arm?
This is the quad LCD (VESA) arm I am looking at.
http://www.amazon.com/gp/product/B001HHNRFK/ref=s9_simh_gw_p229_d2_g229_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-5&pf_rd_r=169W952MNCTKPESHZY7F&pf_rd_t=101&pf_rd_p=470939291&pf_rd_i=507846
pcdoc
Nice, very nice. Great choices. I spent time with Fractal at CES. Great stuff.
G. WadeTech
Thanks. I have been looking at some of the pics and videos from the CES Fractal booth. They will defiantly be a case manufacture I look at when I do another build.
pcdoc
Yep. they have some new stuff coming out in a few months. They would not comment on what it was but they stated it would address some customer feedback. I know that one thing will be to remedy the silly exclusion of a second fan in the front. They have a nice spot for dual fans in the front but they only give you one fan.
    • E3000
      By E3000
      Hey guys,
      Bit of a random question here, and I know it depends on many factors such as what they are doing etc, but how many VMs have you guys comfortably ran on Gen8 with an E3-1265v2 and 16GB RAM? When did you start to see a performance hit compared to what the Gen8 is generally capable of?
    • dxzdxz1
      By dxzdxz1
      This is my first post here but I've been lurking in this forum for quite sometime now, and from what I understand, the only reason that we couldn't achieve 32gb ram on the Microserver Gen8 was because there was no 16gb unbuffered ecc ram available before.
      I was searching for a memory module meeting this criteria and I found this one. My question is, letting aside this ridiculous price, is there any compatibility issue that could make this ram won't work on the Microserver Gen8?
      Most of the threads here about memory compatibility are quite old and I didn't want to revive an old thread just to ask this, so I'm creating this one.
      Thanks in advance.
    • Dave
    • Dave
      By Dave
      The SDM R4 is SOLD OUT!
      The SDM R4 is a bracket that facilitates mounting two additional 2.5″ drives in a HP MicroServer Gen8. There are also mounting holes for fans across the bottom to help cool RAID/SATA cards. The kit includes all the fasteners needed to install.
      With optional Stackers you can run four 2.5″ drives on the SDM R4. The SDM R4 will support four 9.5MM 2.5″ drives. If you want to run four drives on the SDM R4, you need to order SSB stacking brackets listed below. One set of SSB per drive pair, four drives will require two SSB kits. Because of the size of the SDM R4, if you are going to boot your server using the internal USB port, you will need to use a USB stick that is shorter than 1″. For more information on mounting instructions look here: http://homeservershow.com/forums/index.php?/topic/5960-hp-ms-g8-25-drive-bracket-revision-history-new-rev-35-and-rev-4-info/?p=137922
      The SDM R3.5 is in stock and ready to ship!
      The SDM R3.5 is a bracket that facilitates mounting one additional 2.5″ drive in a HP MicroServer Gen8. The kit includes all the fasteners needed to install.
      With optional Stackers you can run two 2.5″ drives on the SDM R3.5. The SDM R3.5 will support two 9.5MM 2.5″ drives. If you want to run two drives on the SDM R3.5, you need to order SSB stacking brackets listed below. One set of SSB per drive pair. For more information on mounting instructions look here:  http://homeservershow.com/forums/index.php?/topic/5960-hp-ms-g8-25-drive-bracket-revision-history-new-rev-35-and-rev-4-info/?p=137922
      SSB-9.5 for 9.5mm drives $10
      Schoondoggy Stacking Brackets can be used to stack two 2.5” drives. All screws are included
      SSB-7 for 7mm drives $10
      SOC-MSG8-R1 kit for 9.5mm optical drives to latch it in place. Screws included $9.
    • Henrik
      By Henrik
      Hi Community,
      First, my specs (briefly):
      MicroServer Gen10
      AMD Opteron X3216
      Win Server 2016
      Problem:
      The Taskmanager shows only 1 CPU-core instead of 2.
      (ref. image 1)
      Solutions tried:
      checked msconfig...no CPU-Limit set checked, whether other users see the same amount of CPU-cores in task-manager (ref. image-link (internal) 2)
      Anyone out there with an idea to solve this?
      Greets
      Henrik
