G. WadeTech
New PC Build... Any help is appreciated.
ImTheTypeOfGuy
In that case go for 32GB...... j/k :)
Now that is my style.
G. WadeTech
I know there are a couple different stress test applications out there to run after I get my new PC setup but what do you guys recommend? Also, I am creating a checklist of pre-tasks, tasks and post-tasks... does anyone have a good checklist or a reference to one that is out on the net?
pcdoc
I use "Aida64" as it is a kitchen sink approach and has a wealth of information. http://www.aida64.com/
ImTheTypeOfGuy
I am my own stress test. Nothing better than that.
G. WadeTech
Originally I was going to have my new pc site in a open front cabinet but I think I am going to have an issue with cable lengths and overall space. So, now I am thinking the new PC will be sitting on the wood floor. The case has a bottom filter for the PSU but what do you think of having the PSU flipped upside down so the PSU fan is sucking air from inside the case? I am not sure that would be a good idea but wonder what others think?
ikon
I think you're right to be concerned about having it on the floor. Certainly wood is better than carpet but still... Only you know how dusty it gets in that area so it's your call. I would say that any amount you are able to raised it above the floor will be beneficial.
As far as flipping the PSU, why not try it and monitor the temps. Also, feel the air coming out of the PSU. If it's not too hot you should be good.
G. WadeTech
I got the new PC built during the CES Keynote and no issues thus far... I am enjoying the upgrade and additional screen. I will post some pics of the new build and setup.
ikon
cool. Pics or it didn't happen ;)
pcdoc
Congrats. I like the crowd sourcing approach unfortunately I get a bit impatient. Good luck with your new build.
ikon
I don't know how you get done all the stuff you do.
    • E3000
      By E3000
      Hey guys,
      Bit of a random question here, and I know it depends on many factors such as what they are doing etc, but how many VMs have you guys comfortably ran on Gen8 with an E3-1265v2 and 16GB RAM? When did you start to see a performance hit compared to what the Gen8 is generally capable of?
    • dxzdxz1
      By dxzdxz1
      This is my first post here but I've been lurking in this forum for quite sometime now, and from what I understand, the only reason that we couldn't achieve 32gb ram on the Microserver Gen8 was because there was no 16gb unbuffered ecc ram available before.
      I was searching for a memory module meeting this criteria and I found this one. My question is, letting aside this ridiculous price, is there any compatibility issue that could make this ram won't work on the Microserver Gen8?
      Most of the threads here about memory compatibility are quite old and I didn't want to revive an old thread just to ask this, so I'm creating this one.
      Thanks in advance.
    • Dave
    • Dave
      By Dave
      The SDM R4 is SOLD OUT!
      The SDM R4 is a bracket that facilitates mounting two additional 2.5″ drives in a HP MicroServer Gen8. There are also mounting holes for fans across the bottom to help cool RAID/SATA cards. The kit includes all the fasteners needed to install.
      With optional Stackers you can run four 2.5″ drives on the SDM R4. The SDM R4 will support four 9.5MM 2.5″ drives. If you want to run four drives on the SDM R4, you need to order SSB stacking brackets listed below. One set of SSB per drive pair, four drives will require two SSB kits. Because of the size of the SDM R4, if you are going to boot your server using the internal USB port, you will need to use a USB stick that is shorter than 1″. For more information on mounting instructions look here: http://homeservershow.com/forums/index.php?/topic/5960-hp-ms-g8-25-drive-bracket-revision-history-new-rev-35-and-rev-4-info/?p=137922
      The SDM R3.5 is in stock and ready to ship!
      The SDM R3.5 is a bracket that facilitates mounting one additional 2.5″ drive in a HP MicroServer Gen8. The kit includes all the fasteners needed to install.
      With optional Stackers you can run two 2.5″ drives on the SDM R3.5. The SDM R3.5 will support two 9.5MM 2.5″ drives. If you want to run two drives on the SDM R3.5, you need to order SSB stacking brackets listed below. One set of SSB per drive pair. For more information on mounting instructions look here:  http://homeservershow.com/forums/index.php?/topic/5960-hp-ms-g8-25-drive-bracket-revision-history-new-rev-35-and-rev-4-info/?p=137922
      SSB-9.5 for 9.5mm drives $10
      Schoondoggy Stacking Brackets can be used to stack two 2.5” drives. All screws are included
      SSB-7 for 7mm drives $10
      SOC-MSG8-R1 kit for 9.5mm optical drives to latch it in place. Screws included $9.
    • Henrik
      By Henrik
      Hi Community,
      First, my specs (briefly):
      MicroServer Gen10
      AMD Opteron X3216
      Win Server 2016
      Problem:
      The Taskmanager shows only 1 CPU-core instead of 2.
      (ref. image 1)
      Solutions tried:
      checked msconfig...no CPU-Limit set checked, whether other users see the same amount of CPU-cores in task-manager (ref. image-link (internal) 2)
      Anyone out there with an idea to solve this?
      Greets
      Henrik
