G. WadeTech
New PC Build... Any help is appreciated.
G. WadeTech
Are there any perks to buying the mobo & cpu at the same time? With some of the mobo deals right now it looks like buying the mobo separate is a better deal.
G. WadeTech
But what I don't want is to buy the mobo and not be able to test it for a couple of months and find out it is bad and not be able to exchange it through newegg.com. This is a hard decision... buying the RAM or mobo and not being able to test for a couple months could be a bad idea. Thoughts?
G. WadeTech
Mobo?
GIGABYTE GA-Z68X-UD3H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128498
GIGABYTE GA-Z68XP-UD4 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128507
Guest no-control
Buy the RAM...
Buy the mobo and CPU at the same time. You'll find better deals if you buy them both. also by the time you're ready to buy both Ivy bridge may be a viable option or at the very least SB will be much cheaper. If it was me I wouldn't buy anything until I had enough to buy the CPU/RAM?mobo all in one shot so you can minimize the risk of getting a DOA.
G. WadeTech
Thanks for the advice. I defiantly don't want a DOA and I am hoping I don't have any boot loop issues with the mobo I get. I will probably wait a bit and get all three at the same time or at least within the same month.
G. WadeTech
Okay, it is hard to build a new PC one piece at a time. Not to mention the issues with not being able to test everything out in case it is DOA.
Yesterday I purchased the CPU/RAM/MOBO/Thermal Paste from newegg.com
I went with the following:
Intel Core i5-2500 Sandy Bridge 3.3GHz
Gigabyte GA-Z68XP-UD4 Mobo
G.Skill Ripjaws X Series 16GB 240-pin DDR3 SDRAM 1600 (PC3 12800)
Artic Silver 5 Thermal Compound
pcdoc
Great choices.
Guest no-control
wow thats a lot of RAM.for a gaming build
Edited by no-control
G. WadeTech
It is not going to be a gaming build really... casual at best. It is mostly going to be my main rig and used to run multiple VM's and development efforts.
ikon
In that case go for 32GB...... j/k :)
    • Henrik
      By Henrik
      Hi Community,
      First, my specs (briefly):
      MicroServer Gen10
      AMD Opteron X3216
      Win Server 2016
      Problem:
      The Taskmanager shows only 1 CPU-core instead of 2.
      (ref. image 1)
      Solutions tried:
      checked msconfig...no CPU-Limit set checked, whether other users see the same amount of CPU-cores in task-manager (ref. image-link (internal) 2)
      Anyone out there with an idea to solve this?
      Greets
      Henrik
    • Sug7
      By Sug7
      Hi Guys,
      New member here, some great info on this forum so hopefully a few of you have experience with the Intel E3-1260L CPU running in a HP Microserver Gen8?
      I know for sure it will work as I’ve seen some good threads on here but can anyone tell me if the upgrade made a noticeable difference in the fan speeds and noise?
      Im looking at putting two Gen8’s in a living room in place of an old N54L so cautious of too much noise..
    • Orion
      By Orion
      I am building a Ryzen machine. Using the new Ryzen 7. What is the best ram to use. Obviously ddr4. And recommendations on brand and size
    • adih2001
      By adih2001
      Hello! Recently I've been thinking to upgrade the CPU in my HP ProLiant ML10 v2. It currently has a Intel® Pentium® G3240 (I got the model of this server that comes with the Intel® Pentium® G3240) and according to the manual I should be able to upgrade the CPU to a Intel® Xeon® E3-1220v3. Is this true? Do I need to change / get anything else? Thanks.
    • 50pence
      By 50pence
      Apologies if posted before but a weird one I’m hoping someone can help me figure out (probably bought the wrong ram! 😒)
      Stock Gen8 with Celeron G1610T CPU & 4GB RAM (
      Upgraded to
      e3-1256L v2 with 65w HP Heatsink
      Offtek 16GB (2 x8GB) DDR3 1600MHz 2R x8 ECC
      Offtek ram was bought sometime ago and registered fine in bios with the celeron.
      Since upgrade of cpu & heatsink - the RAM slot closest to heatsink just doesn’t want to work. Tried swapping ram modules around. Single slots used. The slot furthest away from heatsink seems to work fine with all ram modules.
      See pictures of failures and ram used.
      The bios jut seems to loop around at 30% when Any ideas??
