Zed Posted October 21, 2011 Share Posted October 21, 2011 I have purchased the Rocketraid 2720 for my 2011 server upgrade (wanted redundancy and larger than 2TB drives) - the mb is the Asus P7H55-M/USB3 which has 6x intel sata 3.0 and 2x Marvell 6.0 ports but no raid. The mb was purchased before the DE removal announcement. Has anyone combined one of the drive extender replacements with a raid card - ie do they coexist?. So can I have bunch of disks on the raid card and a bunch of disks on the MB grouped using Drive Extender Replacement. Also if yes, any recommendation on the driver extender replacement to use? thanks Link to comment Share on other sites More sharing options...
ikon Posted October 22, 2011 Share Posted October 22, 2011 Can't see why it wouldn't work technically. Only you can decide if you feel the DE replacements are ready for prime time yet. I said in another post that I wouldn't be afraid to try a DE replacement, as long as I had 2 complete backups of the data on other drives. Link to comment Share on other sites More sharing options...
Zed Posted October 24, 2011 Author Share Posted October 24, 2011 Thanks Ikon - I think i will start with the raid card and add the DE once released Link to comment Share on other sites More sharing options...
