Looking for a small form factor PC to pair with WHS2011 and a Drobo
jcollison
  • Replies 92
  • jcollison
    29
    11
  • Joe_Miner
    9
  • pluggedinpc
    11
Really Jim, I think what you’re really looking for is the HP Microserver – either the lower cost one with AMD Athlon II NEO N36L 1.3 GHz though for a “few dollars more” my preference would be the HP Microserver with AMD Turion II Neo N40L 1.5GHz 2C 2GB – either one I think you could add a USB 3.0 card and sit your Drobo proudly on top of the Microserver
I found this last night while I was digging around, its a bit wider that the drobo, but I think the drobo would look right at home on top of it:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129068
ITX Motherboard with USB3:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128526
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115094
Jim how about this one? Asrock ION 3D
Dementions are good on this one...front USB 3.0 only? Would be better in the back but not a show stopper. This one will make the list...I sense a couple blog posts comeing out of this...
http://www.newegg.co...N82E16811129068
http://www.newegg.co...N82E16813128526
CPU:
http://www.newegg.co...N82E16819115094
I do like the set up here. Case looks good. Board and chip are great. This setup is in the running.
The lowest priced one with rear USB3
Edited by ikon
Jim,
Just a thought. If you get a very small case to pair with the drobo, there is no turning back. If you get a case that has room for at least a few internal drives, at least you can still have a server if the Drobo gives out or you get in the mood to put that raid card to use, you will not be stuck with a case or system you cannot do much with. Just a thought.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112227
http://www.newegg.co...N82E16811112265
